Question on wiring W3 with e.d. nine
Username: Quirky
SA, Texas
Post Number: 164
should i wire it at 1ohm or 4ohm?
at 1ohm the amp puts out 1200wrms
at 4ohm the amp puts out 450wrms
the subs pt is 500w
and its an 8 ohm sub
what should i do?
Thanks,
Ben
Username: Quirky
SA, Texas
Post Number: 165
the main problem is will it be stable or alright at 1ohm?
Username: Philly306
New quote coming soon, North carolina
Post Number: 976
if it is a single voice coil 8 ohm then that is your only option, 8 ohms.
if it is dual voice coil then you can wire it to 4 ohms
Username: Quirky
SA, Texas
Post Number: 166
yes its dual and i could wire it 4ohm and at 1ohm. I want to know if the amp will be stable at 1ohm or if there is any risk in wiring it at 1ohm.
Username: Kravenblood
Ohio Hmmm
Post Number: 401
lol how many subs dvc 8ohm subs you have if its one than you can only wire it to a 16 ohm or a 4 ohm load not 1 ohm meaning you can't run the amp at 1ohm so it would have to be at 4 ohms which is enough for that one sub
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 2501
Are you sure its dual 8ohm?
I know JL made single 4/8ohm and dual 1.5,2,3,4,6ohm. But i dont think they made dual 8ohm.
Ohio Hmmm
Post Number: 402
W3v3's are available in single 2 ohm, 4 ohm and 8 ohm versions (6W3v3 available in 4 ohm and 8 ohm only) um is it an older model..like the original w3's
Username: Quirky
SA, Texas
Post Number: 169
thanks. but i have 2 12" W3v3.8 so I'm guessing I need a new amp.
Username: Quirky
SA, Texas
Post Number: 171
can some one tell me how to wire at 4 ohm DVCs? or would i be under powering my subs so much it wouldn't matter.
Username: Quirky
SA, Texas
Post Number: 172
nvm. i was thinking 8ohm. if i can remember 4ohm is positive to negative then positive to amp negative to amp.
That one, Ohio
Post Number: 403
first stop using dvc.... dvc is a sub haveing duel voice coils your subs are not dvc..
and to hook your subs up for a 4 ohm load you wire the + of one sub to the + of the other then the - of one to the - of the other...
then to hook it to your amp take the + of one of the sub to the + of amp then take the - of the same one to the - of the amp
Username: Quirky
SA, Texas
Post Number: 173
Ya I know. I was totally wrong. I thought they were dual and I went out 2 wire them 2 my car and realized they only had one set of terminals. I feel retarded. I didn't realize they changed the W3 to SVC. Makes a lot more sense now and sry for the confusion.
That one, Ohio
Post Number: 404
they will be ok off 225 watts they will get you could save for another amp if you don't like the output
Username: Quirky
SA, Texas
Post Number: 174
pisses me off. I thought they were 4ohm when i bought them from a buddy of mine who never used them. Any one want them for 300?
