Sound Quality Question
Username: Frkkevin
Post Number: 4791
simple tuning question.. will you really notice a difference going from my parametric 7 band EQ on a 12 band on an EQX
i just don't think it would make much of a difference
Username: Nd4spd18
Northwest PA
Post Number: 6896
Not a big difference, unless you're frequency response is all over the place
Username: Frkkevin
Post Number: 4794
actually im running all flat except the highest freq.. sounds amazing.. i bought an eqx but will probably be selling it since i can do everything i need with just my h/u
Username: Basebalz13
Moneta, Va Usa
Post Number: 364
how much u selling for?
Username: Nd4spd18
Northwest PA
Post Number: 6898
Then I would not expect much of a difference from it at all.
Username: Hittin1
LakeCharles LA., La
Post Number: 73
probably not much difference at all.
