Someone help quick
Username: Drant19
DUB-C, TX
Post Number: 476
im buildin my new box right now...how far apart should i make my pilot holes? every 4, 5, 6in?
Username: Van_man
Boston South, MA
Post Number: 3688
6-8"
Username: Drant19
DUB-C, TX
Post Number: 477
thanks...will do good sir. ill get picks of the final product tomorrow some time.
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 2...
Post Number: 6154
And stay at least 2-2.5" from the corners.
Username: Drant19
DUB-C, TX
Post Number: 478
so ya thats the box so far. i'll finish it tomorrow because my girlfriends family is meetin my family in about 30 min.. wish us luck haha. oh ya if yal want another angle or something up close, ill check this after dinner and post up more.CIMG0123.JPG
Username: Jtown
Team RD, Texas
Post Number: 2558
nail gun ftw!!!
Username: Drant19
DUB-C, TX
Post Number: 480
^ i wish i had one...
A pic is worth 1000 posts!!
Post Number: 14972
I never use a nail gun with mdf. I prefer the control/strength of predrilling and screws. Looks good so far.
Username: Drant19
DUB-C, TX
Post Number: 483
oh yea and this is my first box so....everyone cross your fingers haha
Post Number: 14974
Are you going to cover it?
Username: Drant19
DUB-C, TX
Post Number: 484
i dont think so. i dont really care that much, im more just for the sound than the looks
Username: Drant19
DUB-C, TX
Post Number: 497
the finished product. 4cubes @ 35Hz
Username: Somedonniedude
Illinois United States
Post Number: 1196
Looks good man! Those pioneers going in there? Maybe use the rattle can to cover it?
Username: Drant19
DUB-C, TX
Post Number: 498
yes sir pioneers goin in. my next step up will be a RF T5001
Post Number: 15012
Username: Drant19
DUB-C, TX
Post Number: 500
i got another question or 2:
1. should i drill pilot holes for the sub screws?
2. i dont have the sub baffle to seal them, what can i used, and where can i get it?
Post Number: 1201
I drilled pilot holes in my box and held fine. Caulk will work good from what I've heard, but they say it's kinda hard to clean off.
Username: Drant19
DUB-C, TX
Post Number: 501
anything else that would work well as a seal?
Username: Drant19
DUB-C, TX
Post Number: 502
so i just went n got 1/2 inch foam and used it as a seal. works good. put it in my car and its a HUGE difference from that prefab box.
vids coming soon
Post Number: 15062
It's inevitable in car audio that you will uninstall your gear. Be it amps, subs, or whatever. The only thing concrete built should be your box itself. Caulking or using any kind of adhesive for the sub to box is not advisable IMO. The flexible gaskets will do the job.
