Amp/Woofer pairing suggestions
Username: Ironslave
Offutt AFB, Nebraska U.S.A.
Post Number: 554
i am thinking about getting this woofer but i am curious if i would be safe going over the RMS on it
http://cgi.ebay.com/POWER-ACOUSTIK-15-1300w-CAR-STEREO-SUBWOOFER-AUDIO-SUB_W0QQi temZ170197054641QQihZ007QQcategoryZ18804QQtcZphotoQQssPageNameZWDVWQQrdZ1QQcmdZV iewItem
this speaker is rated for 550WRMS and the amp i have runs at 720WRMS would i be safe to run this Woofer?
Username: M0nkeyman692
Post Number: 513
not a good idea. i mean you could just turn the gain down on the amp so it was only giving it 550 but usually giving a sub more than its rated for is a bad idea.. with a few exceptions..
Username: Snowball123
West Allis, WI United States
Post Number: 425
if you set your gains right you'll be fine.
Username: Hurricanebr1an
Western Burbs of Chicago, IL Usa
Post Number: 372
it would be fine if you set the gain low
but get a better sub than that!!! ugh pwr acoustik...
Post Number: 426
true that.
Username: 420alldaylong
Post Number: 3328
It will work find if it is a nonclipping 720 watts whick means clean signal.
If it was me I would look at these subs first.
Pioneer TS-W307
Pioneer Premier TS-1207
Kicker CVR
Mach5 Audio MAW
Username: Ironslave
Post Number: 556
i was thinking about getting a Kicker CVR, i want a good thump but a good clean sound, i was debating grabbing an MBQuart Premuim woofer, they get high reguards when it comes to sound quality but not to high on the Thump factor.
Username: Ironslave
Post Number: 557
how bout a kicker CVX instead?
Username: Drant19
DUB-C, TX
Post Number: 432
type-r?
Username: Ironslave
Post Number: 559
i was looking at it but i think i might ave found something and i will try to haggle that first if it's still available, a 15" treossi in a box for 250$ on craigslist :-)
Post Number: 3330
Damn dude I thought you were on a tight budget but anyways check these subs
AudioQue-SD2.5
Diamond-D6
Eclipse-SW7200
Fi-SSD
Which ever sub you decide on make sure that the box you go with is built for that sub. Or you could build your box itss not hard to do.Good Luck
Ascendant Audio-Arsenal
Username: Ironslave
Post Number: 560
i am but i'm not... i am trying to keep tight cause my wife would kill me if i spent 250$ but i have the money to do it.... :-( it sucks.
Username: Hittin1
LakeCharles LA., La
Post Number: 25
Treo is one of my fav's you wou8ldn't be dissapointed.
Username: Xxjustjxx
Jersey City, NewJersey United States
01 Cad Deville I have 2 10" RF HX2's and a JL 500/1 Amp! Wat Box? Sealed or Ported Box? 2 singles or 1 double?
Post Number: 3355
More power.
Ported box to there spec.
One box for two subs.
Username: Xxjustjxx
i don't know what you mean "to there spec.". How do i know what there specs are?
Username: Denali_on_22s
The kids love my rhyme...
Post Number: 4722
looks them up...
Username: Xxjustjxx
how do i looks them up? lol
