My not so loud system HELP WITH GAIN
Username: Deadrabit
Post Number: 218
so i just went out and reset me gain again. i didn't see what it was set at before but i am pretty sure that was the problem. now it is at 31.6 volts with it turned up all the way with the bass boost and everything off. should i set it again with the volume 3/4 of the way?
if i do that would it be ok to turn it all the way up with the bass boost and everything on?
i am pretty sure this was y i only got 142. it went from flexing a lot to my grandma screaming "your windows are about to break"
Username: Th3pwn3r
Post Number:...
Post Number: 7109
If you set it again with the volume 3/4 of the way up and you actually play it above 3/4 you're going to possibly clip if you're using the same signal source.
Username: Deadrabit
Post Number: 219
but i am guessing i leave the amp volume from the head unit off when i set the gain and then i can turn it up when i am done?
i mean i don't want to blow my sub but if i don't turn that up it does not hit hard at all off of 31.6 volts
Username: Deadrabit
Post Number: 220
looks like its time for a new amp... i am going to see what it hits tomo. i hope 146! then ill go from there.
so with the gain set for the volume all the way up it will be ok to have the boost and all that crap on too with the volume up all day way?
Username: Mike11202
DD9515G VFL 200.1 = : , Sewell, NJ US
Post Number: 1379
if you have a pioneer head unit you can set it at 61/62 before it clips
Username: Deadrabit
Post Number: 221
i have a kenwood. it says its .01% distortion.
i don't don't think i have ever had it clip before. will i know if it happens?
Username: Somedonniedude
Illinois United States
Post Number: 1119
If your clipping, your sub will usually get really warm or hot, just feel the dust cap after a a good 5 min session.
Username: Shade
Moxee, Wa U.S.
Post Number: 614
what kind of amp and sub is it again?
and what kind of head unit do u have?
Username: Deadrabit
Post Number: 222
itsa rockford power 1000.1 and a FI 18 in BL
kenwood head unit
Username: Insearchofbass
Post Number: 8295
"if you have a pioneer head unit you can set it at 61/62 before it clips"
LOL
Username: Talon01
Team Revolution , Pa Usa
Post Number: 990
Username: Nd4spd18
Northwest PA
Post Number: 6652
3/4 is a safe bet for all HUs so use that
Username: Deadrabit
Post Number: 224
what is HU?
Username: Nickyp0219
Post Number: 847
Head Unit
Post Number: 8311
Benjamin Lukas Kennedy a 142 db daily system isnt weak... it might not be the best score for an 18 but then again you dont know for sure what your best hit frequency is ...the sub probably hits more than 142 in your current box on the right test tone
Username: Deadrabit
Post Number: 229
ur prolly right.. cause i am going to say i think my box is pretty good.
i will have some more test tones on tuesday from this dude that is some kind of record.
he got 166 db in a chev love with 2 18s. which.. he did have like a million watts and it was not a daily driver.
EITHER WAY! i need to talk to scott from FI and see what the best volume should be for my next box. i am going to use some of these test tones and see what my car is tuned too and make my next box the same. i am thinking sub facing up and port facing back.
with all that i should get a much better number! maybe even up in the 150ish range at the dash i hope. . i did just order a butt loud of hushmat
Post Number: 8327
just make a test tone cd that has tones 1 hz apart that way youll be sure to find your frequency...but youll find out it can vary
Post Number: 854
not to jack your thread Ben, but I got a question
(dont want to create a new thread over this)
I heard a couple people say on here that the "LOUD" function on the HU is ok to use.
I specifically remember M.S. and others telling me that it is a form of bass boost, isn't good, and not to use it.
so which is it? can someone clear this up for me
Username: Redliner
Wilmington, Ma
Post Number: 4119
dont use it
Username: Deadrabit
Post Number: 241
ok.... don't use it then haha
Username: Nd4spd18
Northwest PA
Post Number: 6727
It is a bass AND treble boost, doesn't boost the midrange. Which creates a bad frequency response.
