S-video cable????
Username: Basebalz13
Moneta, Va Usa
Post Number: 284
where can i find a S-video to the 3 RCA cable at? (the 2 audio RCA's and the Video RCA) i see them on ebay but i think they just some cheap stuff
Username: Nd4spd18
Northwest PA
Post Number: 6731
If any store is going to have it, Radioshack will.
Moneta, Va Usa
Post Number: 285
thanks
Username: Durski
Post Number: 325
S-video is only video. Correct me if i'm wrong but im pretty sure you can only get video out of it, i.e. 1 rca for video.
Username: Durski
Post Number: 326
http://www.cablestogo.com/product_list.asp?cat%5Fid=2012&cm_mmc=AdWords-_-07-OKA Y-_-s-video+to+rca_779086221-_-s-video+to+rca_Exact_%7C-%7C100000000000000132624 &gclid=CNXwguvmhZICFQJ-xgodY05S9g
That may be what you're looking for, with the s-video to yellow rca for video, and the green headphone style cable to red / white rca audio. That's really 2 cables bound together, and audio Y cable and an s-video to rca cable.
Username: Nd4spd18
Northwest PA
Post Number: 6737
That is correct you connect the audio seperately.
This cable is the type he needs for the video.
http://www.cablestogo.com/product.asp?cat%5Fid=2012&sku=27964
Moneta, Va Usa
Post Number: 293
hmm, well heres what im tying to do, i am tryin to run my stereo system throught my laptop, i have been using 3.5mm jack to the 2 audio RCA plus, but i would like to instead go through S-video cuz i thought it would be a better connection, so no sound goes through the S-video??
Username: Durski
Post Number: 331
Well if your stereo can handle it as an input, and your laptop puts it out, you can always try it....... But my initial answer is No, I have not seen s-video do anything but video.
Username: Nd4spd18
Northwest PA
Post Number: 6744
S-Video is just that, video. The audio goes through the RCAs, same as if you were using composite video (the vide RCA jack).
Moneta, Va Usa
Post Number: 295
deeernnnnn, any other ideas?
Username: Nd4spd18
Northwest PA
Post Number: 6751
RCA connection is the only way to do it unless both your stereo and laptop have digital audio jacks, which I 99% bet they don't.
Moneta, Va Usa
Post Number: 301
ummm well when i was lookin through my control panel under sounds, it has teh speakers/headphones(sigmatel high definition audio CODEC
then a Digital Output Device(spdif out) (sigmatel high definition audop CODEC
the speakers/headphones is the one that is checked
Username: Nd4spd18
Northwest PA
Post Number: 6755
That has nothing to do with physical connections
Moneta, Va Usa
Post Number: 304
o0o haha dayum, cuz when i clicked on it to see more information it said location, rear panel RCA jack
