Chad Lee
Username: Mike11202
DD9515G VFL 200.1 = : , Sewell, NJ US
Post Number: 1526
I see you have the CDTs for sale up on eBay, PM how much you want shipped for them.
Since I'm stuck with some cheap coaxials right now I need an upgrade.
Username: Mike11202
Post Number: 1527
actually just use mmike11202 at yahoo.com
Http://www.rdaudio.net...
Post Number: 19153
is mike spelled with 2 m's?
Post Number: 19154
email sent
Username: Mike11202
Post Number: 1528
yeah
Post Number: 19155
cool. ygm
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2246
chad i didnt want to start a new thread but i figured this would get your attention.
You probly saw my other thread with the btl intsall but it isnt nearly as loud as i expected it to be. Its getting 200rms but another friend of mine has a type-r and its just about as loud and i was wondering how your BTLs sounded and if they were plenty loud. I guess it could be the box i built for the BTL thats making it the way it is but its 4.2 net tuned at 33hz. just about 60sq of port. i was wondering if you had any thoughts
Username: Th3pwn3r
Post Number:...
Post Number: 7278
The problem is that you're only giving it 200 RMS.
Username: Philly306
New quote coming soon, North carolina
Post Number: 962
he meant 2000. it has a aq 2200 on it
Username: Snarl2004
Post Number: 2247
my bad ya 2200 rms*****
Post Number: 19303
i am not sure snarl. but when i had mine, i had at least 2500wrms on mine and it was loud.
what are the box dimensions?
also did you set the gain correct on the amp?
check all your settings good.
Post Number: 19304
oh you did put your box specs. lol.
that box seems cool. maybe its the settings on the amp.
Username: Snarl2004
Post Number: 2248
double and triple checked settings. gain is perfect and set with a dmm. box dimensions are 28" wide 19" tall 20" deep *(those are the rough dimensions off the top of my head)
about how much excursion did yours have? and did they get louder as they broke in?
Username: Snarl2004
Post Number: 2249
like i expected the BTL to have my 9515 a run for its money but i was a little disaponted with the BTL. i think i may take my 9515 out of my box and put in the BTL and hook it up to the AQ 2200D and see if i get better reults...thats the only thing i can think of mabey the box isnt ideal or something along those lines.
Username: Stateprop486
PA
Post Number: 1100
^^ thats the risk u gotta take sometimes with car audio... sometimes u mite b satisfied with what you had b4, n may not be satisfied with what u just bought to replace it....
