Gain wire melted
Username: Guntha3
my gain wire melted when i was cranking today. Is it because my wire is not long enough ( its about a foot 1/2)?
A pic is worth 1000 posts!!
Post Number: 14635
Gain wire?
Username: Stateprop486
PA
Post Number: 1039
gain wire? wtf.... u mean power wire, ground wire, or remote wire....?
Username: Ska
Post Number: 653
how is it melting anyway? do you not have the same size wire as your power (assuming its your grownd) is there paint between the wire and yoru car?
Username: Prozack52
Cincinnati, 2-D615D4 Dia...
Post Number: 154
all i can say is lol
Post Number: 14638
Everyone makes mistakes Gunther. Please explain further so we can help you from melting another wire and possibly causing a fire.
Username: Prozack52
Post Number: 156
yes everyone does make mistake my bad i have done a WHOLE lot worse believe me how about when i first started in car audio i burnt up my 800 dollar amp that was a shot to the gut but i learned never to do what i did again
Username: Clouduz
Post Number: 317
lol the first thing i thought was...."sh*t Idon't have a gain wire, I must have brought a cheap azz amp"
Username: Th3pwn3r
Post Number:...
Post Number: 7218
I think he's talking about the wire that goes to a remote knob.
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 2...
Post Number: 6119
My guess is he ment 'ground'.
Make sure you have the proper size ground and you have a solid ground.
What amp do you have?
What size power/ground wires are you currently using?
Username: Jtown
Team RD, Texas
Post Number: 2515
I think he is talking about the "bass knob" or "gain attentuator" wire, but I could be wrong
Post Number: 6120
He said it 1.5ft.
Prolly the ground.
Username: Th3pwn3r
Post Number:...
Post Number: 7219
^Don't assume anything Canaan. People do the craziest things.
Username: Spivey17323
Dunellen, New jersey 15 inch Alph...
Post Number: 1456
were u using the same gauge power wire as ground? this happened to my friend and he melted the shi t out of his wire because he was using two different gauges for power and ground
Username: Van_man
Boston South, MA
Post Number: 3623
all explained here.
https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=4&post=1479535#POST1479535
Username: Guntha3
be easy, i meant ground. my power wire is 4 gauge and the ground is 8 gauge. i guess i see my problem? Go with a 4 gauge ground?
PA
Post Number: 1053
yea bro alwys use the same gauge for power n ground wire...what amp r u running? how many watts? nething above 1000watts u might want to switch to 1/0 gauge wiring.
Username: Guntha3
jbl 1200 . 2w6v2
Username: Jkidder
Gunshine , State Flawda
Post Number: 3335
nice setup gunther
Username: Clouduz
Post Number: 318
yea NEVER use a smaller ground than the power wire you can use a smaller power and bigger ground tho, but yea doesn't make sense to do that
Username: Van_man
Boston South, MA
Post Number: 3628
Did everyone miss this?
RMS Power (1 ohm) Not Stable
2 JL 12W6V2 equals 1 ohm or 4 ohm.
Is it wired to 1 or 4 ohms Gunther? or maybe 10, 16?
Username: •cam•
BC Canada
Post Number: 2170
I remember there being a JBL amp that I was looking at that, although it wasn't rated for it, would drive an ohm just fine.
Username: Guntha3
Post Number: 7
4ohms
