My Temp Setup
Username: Dakangofkrunk16
Boca Raton, Florida
Post Number: 1291
Ok i have a Kole Audio HK1920-2 and i'm gonna get a temp sub for now... until i get the LMS ultra.. So I'm Thinkin Fi SSD 10inch... Cheap and the Enclosure only needs to be 1.5 cuft at most..
The amp says it can do 880 Watts RMS Mono... I'm guessin that is it bridges at 4 ohm's but any ways i know it isnt a great amp and prolly wont produce that much but idc it is better then nothing
Any other suggestion on Subs will be good Here are Specs of amp so you know what sub to look for
# 2 Ohm Stable: 2 Ohm Stereo Stable
# 4 Gauge Power/Ground Connection
# Diamond Cut Heat Sink
# Gold Plated RCA Connectors
# Line Output
# PWM Circuitry
# System Distress Indicator
# Three Way Protection Circuit
# Tri-Mode Capable
# Variable Subsonic Filter 60Hz-200Hz
# Bass Boost Circuitry: Variable 24 dB Bass Boost
# Crossover: Full Selectable Crossover Hi/Full/Low
# Dimensions: 22" x 3.3" x 9.0"
# Frequency Response: 10 Hz to 30 kHz
# High-Pass Crossover: Variable High Pass 50Hz-500Hz
# Low-Pass Crossover: Variable Low Pass 30Hz-500Hz
# MOSFET: Full Mosfet Power Supply
# Signal to Noise Ratio: 98 dB
# Total Harmonic Distortion (THD): 0.02%
Power Ratings
# Bridged Power: 1920 Watts Bridged
# RMS (Continuous) Power: 370 Watts x 2 @ 4 ohm
# RMS (Continuous) Power: 440 Watts x 2 @ 2 ohm
# RMS (Continuous) Power: 880 Watts Mono
Subwoofer Size can be any.. IDC its a temp setup and i dont wanna have to build a Giant Box thanks for help
Price between 0-200 Maybe a lil more
Username: Th3pwn3r
Post Number:...
Post Number: 7270
Looking for new or used? Have you checked on CA.com?
Username: Th3pwn3r
Post Number:...
Post Number: 7271
http://www.caraudio.com/forum/showthread.php?t=296922
Boca Raton, Florida
Post Number: 1292
Thanks for that.. but yea needs to be New cause when im goin to sell it cause it is a temp i dont want it to be a double used Sub and go down in value double you know... 10 12's are welcome
Username: Denali_on_22s
The kids love my rhyme...
Post Number: 4658
double used? wtf? a used sub is a used sub no matter how many hands it has been in. unless it was abused, it doesn't matter.
Boca Raton, Florida
Post Number: 1293
Btu a sub that has been used by more then one person is worse then a barely used one... More Cosmetic Damage and Other damages..
But nay ways any other suggestions
Post Number: 4690
that's not necessarily true at all, but whatever. buying a sub isn't an investment you'll never get what you put into it out of it so dont worry about it.
Username: Joebruce
15 AQ HD3
Post Number: 1802
Buy all of Pauls eqhs 8s
Username: Th3pwn3r
Post Number:...
Post Number: 7282
You could easily re-sell the sub for 100 dollars that I posted. It also looks like it's in mint condition.
Username: Stateprop486
PA
Post Number: 1108
"buying a sub isn't an investment you'll never get what you put into it out of it."
^^ i think that statement is true for anything you buy.....unless if you gotta good deal for the item..
Http://www.rdaudio.net...
Post Number: 19318
i think the ssd will be a nice choice. besides you need a fi sub to go with your fi shirt you bought.
anyways, buying used should be okay as long as you know who used it. for example yanks fan has one for sale i think.
Boca Raton, Florida
Post Number: 1296
"besides you need a fi sub to go with your fi shirt you bought."
LOLLOLOLOLOL
Correction Fi
But sadly i was in my wearing baggy clothes stage which im not nay more and the Shirt is to big lol
IT's and XL i weight 152
Post Number: 19319
seriously though, i can't think of any temp subs better than the ssd. who knows if you use it good, i might be the one buying it from you later when you get the lms ultra.
Boca Raton, Florida
Post Number: 1297
LOL you just want me to get it so you can buy it off me.. lol Yea but for 175 the 10 is looking very nice... I was my first choice.. Chad why would you want a 10inch dont you want to be SPL again...
Post Number: 19321
no i have a few people that would buy it. lol. its not for me.
Boca Raton, Florida
Post Number: 1300
oh lol ok... So what is ur next setup gonna be... I dont know what setup you have now.. but i know u was sayin you want a SPL setup again...
