Best 12'' sql sub/s for zx 750.1
Username: Schinner
Post Number: 65
just wondering what would be a good setup for the zx 750.1 amp. looking for sql.
what is usually the better option 2 cheaper 12s or one, more expensive sub? i wont discount the option of a 15 if that would be the better choice.
right now ive just got 2 10'' cvr's in a sealed box, obviously geared more towards sq. i do listen to a lot of rock but find i need more bass for hip-hop and rap.
thanks guys!
Username: Nd4spd18
Northwest PA
Post Number: 6162
Two 12s > one 15....... more cone area
Username: Schinner
Post Number: 67
alright well....what are some good sql subs....that would match with that amp?
Username: Skibum12189
Cleveland
Post Number: 2611
i'd go with 2 diamond d312d2's....
Username: Somedonniedude
Illinois United States
Post Number: 948
Whats your budget? D3's are a solid choice.
Username: Mendonmafia
Post Number: 1185
kappa perfects! they sound amazing and get pretty damn loud doing it. just watch the video i posted of my friends civic.
Username: Nissankicker
Grambling, LA USA
Post Number: 235
I have (4) 12" Eclipse SW7200s
... Since they're Dual 2s, if you got (2) you'll be @ a 2-ohm load. Perfect for that Amp.
I tested 2 in a SuperBass Probox Ported Enclosure, on a ZX1000.1, and it was LOVELY!!!
Username: Schinner
Post Number: 68
the d3's deffinately look like a great option.
now if you had to choose either the kappa perfect or the d3 which would you go with, sql maybe leaning a little more towards spl.
