Dual XDVD8181 bypass wont work please help
Username: Tak4
Hello,
Just today i bought a Dual 7" XDVD8181 and installed it. Everythin works perfect, plays CDs and raidio.
I grounded the break wire and put a DVD in and got the message "against the law to play while in motion, put e break on to play" but the ebrake was still on, so i took it off, but didnt go away.
Then i tried to tap the break wire to the black wire (ground). and still go the same message.
Then tried the different codes.
DVD, stop 2 time 26604 or somthing, and the CD one. Still doesnt work.
Any one know how?
Thanks
