Prefab box question
Username: 2pacalypse1971
Sandusky, Oh
Post Number: 464
ok i have a prefab box for 2 12 that is ported, i bought this a while back, and i'm thinkin of ordering two 12's, no nidea which ones, but i don't really want it ported no more, say i got a piece of wood and screwed it over the port, would that be considered a 'sealed' box then??, because i jsut wnat a normal sealed box
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 1385
not really lol its still gonna leak air out unless u seal it up with wood glue or somethang
Username: Nd4spd18
Northwest PA
Post Number: 5307
Just get a real box
Username: Nickyp0219
Post Number: 293
why dont you want ported any longer?
Username: Cblaze
Post Number: 1390
ported will kill any sealed box.ported is for spl,u said that was what ya wanted
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 1096
Just build your own box.
Sandusky, Oh
Post Number: 465
cuz them prefab ported boxes sounds like Sh!t in my opinon, i guess i'll have to have box built whenever i do end up gettin some new subs, building aruond the subs that is
Username: Cblaze
Post Number: 1392
use this site to design the box
http://www.subwoofertools.com/forum/ported-box.asp
Username: Mdcustoms
Grand Rapids, MI USA
Post Number: 25
You could do that but I would not recommend it. Ported enclosures are going to be bigger then sealed enclsores. So if you seal the port you are going to have a real large sealed enclosure. That could sound even worse.
www.MDCustomz.com
