DD Amps
Username: Wylie_coyote
Post Number: 134
So after hearing so many good things about DD i decided to start saving for a 9515 but i also need an amp to power it, so i was thinking why not go for like a DDZ its rated for 5000 watts 1 Ohm, but not too sure if thats RMS though.
Then i realised that i haven't really heard anything about Digital Designs making good amps. So thats basically my question should i bother setting my sights on that amp or not??
(toal savings so far for DD sub £100 ooh yeah)
Username: 04redmach1
Columbus, GA USA
Post Number: 1538
The DD amps are ok. If I were you, take a look at the Adessa line of amps. They are located in Europe and shipping may not be as bad. Are you looking at running 1 or 2 9515's?
Kevin
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 1142
its there subs everybody wants,incredibly loud and sound awesome,havent heard anythang bad about the amps tho
Username: 420alldaylong
Post Number: 3049
Get two AQ1200D $299 each after Jan. 1st strap them together and you got 2400RMS+ that would bang the sh!t out of that DD9515".
AudioQue.com
Username: Nd4spd18
Northwest PA
Post Number: 5025
DD amps are as good as their subs
Username: Jkidder
Gunshine , State Flawda
Post Number: 2964
x2
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13418
DD amps are good...there older ones are mad underated...
not sure about the price on any DD item tho..
Username: Jtown
Team Revolution, Texas
Post Number: 1487
or instead of two AQ1200Ds get one AQ2000D also coming out in late january ~$440 shipped....should do around ~2400wrms maybe more on a good charging
Username: Safe_cracker
Chicago, IL US
Post Number: 3815
DD Z1a, that is the amp to have! I blew one because I mounted it to the back of my box but I am able to repair them so I won't cry over a $1400 blowup, lOl. I just got a IA 40.1 for a backup and dude this amp puts out mad amounts of power plus is smaller than my Z1a. Polo..
Post Number: 13433
IA FTW...the 20.1 is one of the most efficient amps that i have ever dealt with
Username: Pbplayer05
Carroll, Iowa
Post Number: 173
does anyone have pricing n dd amps?
Carroll, Iowa
Post Number: 174
does anyone have pricing on the amps
Username: Cblaze
Post Number: 1176
ive been offered 429 for a m1,but this dealer sell stuff cheaper than others,ive thought about getting a 3515,but there prolly wouldnt be any difference between that and my sx 15
Username: Demon_pride
Crowder, Oklahoma USA
Post Number: 234
^ Yes there would. I had two SX 12s and this single 9512 is louder.
Username: Cblaze
Post Number: 1194
got any db numbers to show me the difference then.from what ive seen the numbers to a 3515 a re sx are just about the same
Post Number: 235
I'm comparing my DD9512 to two SX12s.
Post Number: 13437
on the same amount of power...the 2sx's would dominate Any DD sub...
Username: Cblaze
Post Number: 1200
thats what i was thanking,sx's can get very loud,dd and re is on the same level imo,2 3512's and 2 sx 12's would be more comparable
Username: Cblaze
Post Number: 1202
well a 9518 would prolly kill the 2 sx's in output
Post Number: 3073
I seen DD amps on that TV show (Psych) just thought you would like to know that.
Username: Nd4spd18
Northwest PA
Post Number: 5057
^^^ what is this now???
Post Number: 3074
TV show (Psych)
Post Number: 3075
I would take two Fi BL 12" or RE SX12" over one DD9518" in output on the same power.
Username: Cblaze
Post Number: 1214
hmm i always thought a 18 would be louder than 2 12's
Post Number: 135
Kevin:- I'm only looking to get one, i wanna try and keep as much storage space as i can and from what i hear this DD sub will be perfect foer the sound i want without investing in multiple subs and amps and things.
you know i was trying to remember the name of Adessa so i could check they're amps out i just couldn't put my finger on it.
The mission statment for this new setup is spend big on quality sounds that will last for many years to come.
Username: Nd4spd18
Northwest PA
Post Number: 5065
It would be about that same. The 18" has the advantage in cone area but the two 12" subs would handle more power.
Lagrange, GA USA
Post Number: 1556
Ah ok, gotcha. Check and see what Adessa wants to charge for one. But IMO, I would go with no more than 3000 rms to be safe :-)
Kevin
Chicago, IL US
Post Number: 3833
Actually, if you are looking for a sub that will get extremely loud on the 3K and only require a 3CF net box then look no further than a TC Sounds 5200 15"! This sub requires such a small box because of its extreme BL great sub and it will handle a lot of power, have mine on a IA 40.1 right now! Polo..
Username: Somedonniedude
Illinois United States
Post Number: 652
Whats the difference between that sub ^^^ and the lms ultra?
Username: Cblaze
Post Number: 1234
them subs are crazy loud,nice sub polo
Chicago, IL US
Post Number: 3844
LMS is a linear driver, uses a Linear 4hp motor with extended throw but it is inherently inefficient due to the extra large pole gap needed for the coil. Now the 5200 uses a 4hp non-linear motor with not as much throw but has an extreme BL of around 43, nearly double that of the linear, has an effect on ports, makes for a louder driver nearly 3db louder. Both are great subs but the 5200 takes up less space and can be ran on less power if you wanted to. Polo.
Username: •cam•
BC Canada
Post Number: 1475
Lots of generalizations in this thread. It's quite dependent on car/installation.
Post Number: 144
the 5200 looks quite nice actually and if it performs as well as you're saying then it'd be perfect. but i'm still leaning more towards the DD sub though, its captured my heart for some reason :-)
Username: Zacdavis
Beloit, Wi
Post Number: 1486
The DDZ series sub will cost in excess of $2500 us dollars.
9500 series with composite cone will be much more affordable and still perform at world class levels.
DD amplifiers are outstanding! Call around to find a dealer close to you for pricing on all products.
The M3 has plenty of power to run a 9515.
The M3 was 1.2 db higher than the modded MMats 3500.05 in our testing.
Each amp at 1/4 ohm in same car, same box, same subs, same everything, direct drop in results....
158.5 Mmats
159.7 DD M3
Resting voltage = 13.1
M3 voltage drop= 12.1
MMats voltage drop= 12.4
Post Number: 151
Nice one Zac. Appreciate your information mate.
I'm starting to learn about the high price of DD but still if its quality you want.............
