4 channel amp to a Dual 4 ohm sub..
Username: Sexy_kuta
Post Number: 99
purchasing a se15,
would a XT1600.4, 450rms at 2ohms X4
someone told me that running a 4 channel amp to a sub is a bad idea. something about Intependant gains and crossovers for each voice coil.
could someone explain to me that?
Username: Nd4spd18
Northwest PA
Post Number: 4856
A class D (mono) amp is what should be used for subs, simply because they are a LOT more efficient than a 2 or 4 channel amp.
Username: Sexy_kuta
Post Number: 100
would there be a problem in running a 4 channel amp?
Username: Nd4spd18
Northwest PA
Post Number: 4864
Yeah sort of. With a 2 channel amp you can bridge it to 1 channel for a sub, but a 4 channel amp can only be bridged to 2 channels.
Also the low efficiency puts a major demand on your electrical system.
Username: Sexy_kuta
Post Number: 101
what if i bridged two channel to a coil
and the other two channels two another coil?
its a dual 4 ohms
Username: Nd4spd18
Northwest PA
Post Number: 4869
You wouldn't get much power out of it that way. If it were dual 2 ohms you could do that but you would have to make sure the settings for both channels were exactly the same.
Username: Sexy_kuta
Post Number: 102
damn, I guess i'll have to wait and look at somethign good for an amp.
what do you guys recommend?
Username: Sexy_kuta
Post Number: 103
how about a xt1600.2
Dynamic power: 1600w
RMS power (2ohm): 400w x 2
RMS power (4ohm): 200w x 2
Bridged power (4ohm): 1100w x 1
Username: N2audio
Lawrence, Ks USA
Post Number: 1433
between the 2 I think the 4 ch is the better option. You can run 2 bridged channels per coil - like you mentioned. I don't see a problem.
I would use a DMM to match the gains, and y cables to split your HU's sub or rear output to make sure each coil is receiving the same signal, or as close as possible.
However - at $300-$350 there are definitely better options.
Username: Somedonniedude
Illinois United States
Post Number: 600
kicker kx600.1
rockford t5001bd
Both on ebay for about $200 shipped.
Username: Killuarstan
Nanticoke, Pa Usa
hey i have a pdx alpine with 4 cannels how do i bridge it no one can tell me how to do it
Nanticoke, Pa Usa
with two kicker comp 4 ohm each and i dont have the manual any more and cant find a good one online
Username: •cam•
BC Canada
Post Number: 1527
It should be in the manual.
