Nine.1 or Audioque 1200D
Username: Rellikfl
New Port Richey, FL USA
Post Number: 35
Anyone have experience with either? They both put out about the same RMS @ 1ohm and both cost about the same.
Which is better?
Username: Rellikfl
Post Number: 40
even tho the AQ isnt out yet.
Username: Nd4spd18
Northwest PA
Post Number: 4892
AQ
It is supposed to be similar to DD amps in quality, and in that case it will own :-)
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5081
get the cheapest one
Username: Hurricanebr1an
Western Burbs of Chicago, IL Usa
Post Number: 305
AQ
Username: •cam•
BC Canada
Post Number: 1368
"get the cheapest one"
X2. You'll be happy either way, so spend the least amount of $$$ you can.
Username: Rellikfl
Post Number: 68
Just ordered the AQ. Cant wait to hook it up to the 12's
