Amp for 9818
Username: Kingtutus
Lincoln, Nebraska U.s.a
Post Number: 16
looking for a amp that can do about 3200rms
for daily driving. price range is about $800
Username: Loudon
Post Number: 2102
rd 3250.1
Username: Kingandsons07
Lincoln, Nebraska U.S.A
Post Number: 389
he means 9917 or 9518?
Username: Nd4spd18
Northwest PA
Post Number: 4635
Yea he mistyped. No such thing as a 98 series.
Username: Kingtutus
Post Number: 20
yeah my bad, so what is a good amp for it.
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 4964
IA 40.1
Memphis 4kw
Autotek MM4000.1
RF T40001bd
just to name a few..
Username: Jkidder
Gunshine , State Flawda
Post Number: 2930
rf might be too much for it but the others are good. ive seen those putting out 5k
Post Number: 4970
some RFs are insanely underrated.
Username: Drant19
DUB-C, TX
Post Number: 113
get the RF just incase u want to upgrade later. dont know how much they are tho.
Post Number: 4972
theres on for sale on CA.com
i think hes sellin it for like 1000 though
Username: J_baby15
Murray, Kentucky
Post Number: 2107
memphis 4kw on a 9918 gets very loud
Username: Jnoel
AIM= j69noel, KY
Post Number: 747
^ yea dd9918 on a 4kw is hella loud
Username: Zacdavis
Beloit, Wi
Post Number: 753
You should post some pics when you get it installed. I love Digital Designs subs :D
Is it red or yellow?
I think I like the yellow ones best.
Anybody see the gray Z sub on ddaudio.com?
To answer your question, and theres been some great suggestions so far, I would have to know what the ohm load is of your sub.
If its a dual 1 i'd go with a Mmats 3500.05, (also the earlier 3000.05 is actually stronger than the 3500.05, sounds crazy but true.)
If its a dual 2 or .5 then all the other suggestions are great to.
So whatcha puting it in?
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 935
"some RFs are insanely underrated."\
punch serries might be,but my power series amp is like 2 months old.and came with a birth sheet of doing double the power its rated
Username: Nd4spd18
Northwest PA
Post Number: 4672
Umm, thats what underrated means, they do more than rated power.
Username: 04redmach1
Columbus, GA USA
Post Number: 1489
I can give you a great deal on a 3250.1 from RD. Shoot me an email.
Kevin
lowhz01@yahoo.com
Username: Kingtutus
Post Number: 31
i think that i an going to do 2 18" FI btls in a 10.5 cubic foot box but need a amp for it.
Username: Livin_loud
Do Work Fi Audio
Post Number: 2092
you have no idea what kind of electrical upgrades you will be needing, do you?
Username: Nd4spd18
Northwest PA
Post Number: 4689
Actually I think he does, I think I saw it in another thread
Username: Kingtutus
Post Number: 32
yeah i no that, im going to put a 300amp alt and run like 2 to 3 batts what ever i will need
Post Number: 403
what dose he all need? 300 amp alt Big 3 umm 3 HC2400 and one HC1800 under the hood or dose need more o and a run of 4/0awg lol
Username: Nd4spd18
Northwest PA
Post Number: 4691
Thats alternator and 1 battery will do just fine. For those amps youre looking at, 1 or 2 runs of 0 gauge wire.
