Car sub for home audio?
Username: Themann
Mt. Holly, NC USA
Post Number: 120
How would I got about using a kicker cvr12 I have laying around for my computer subwoofer. Because my suite mates in my dorm need to know what real bass is when they least expect it...
Username: •cam•
BC Canada
Post Number: 1303
Build a little box for it, get a plate amp (search Parts Express, eD), a 3.5 mm stereo plug splitter, and a 3.5 mm stereo plug to RCA adapter.
Username: Calioldschool
California
Post Number: 40
I would not recommend doing this, go buy a home theatre subwoofer.. not a car woofer.. you will never get enough power to the sub for it to sound as good as a car unless you spend a lot of money for a power supply ($500+)... do it the right way :-)
Username: Jtown
Team Revolution, Texas
Post Number: 1277
what cam said will work, but what anthony said will prob be cheaper for you
Username: Tatonka
-[Team Audib...
Post Number: 1137
It's not like hes building a HT system. He just wants to have something as a computer sub. Go with what cam said if you want something that will just sound decent.
A pic is worth 1000 posts!!
Post Number: 11791
You can get a 1000w plate amp for about $340 or so. That's plenty of power for the home. Trust me.
-apem
Post Number: 16145
i was looking at one of those paul on partsexpress.com. it does 1000wrms @ 4ohms so its perfect for my rl-s 12. next year i will be moving my subs in to my house and try something different.
Post Number: 11793
Get your groove on Chad.
Username: M0nkeyman692
Post Number: 427
bump..
Username: Kingandsons07
Lincoln, Nebraska U.S.A
Post Number: 375
whats the link for the plate amp for about $340 paul?? thanks man
Username: Goodie_goop
Mid town, Texas U.S.
Post Number: 781
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-810
dont know if its the one they are talkin about but i was lookin at this one for the alpha i have laying around :-)
Post Number: 11802
Actually it's this one.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-808
$330 is a good deal. It's also the one I use with my Q. Also with my Mag. I absolutely love it.
Post Number: 378
thanks now do i need a ssf on it?? or dose it come with one? thanks paul
Post Number: 11803
From my knowledge it doesn't.
Are you planning on a sealed or ported enclosure?
Subsonic filters are used mainly for ported enclosures to keep the sub from over exurting, usually below 20 hz. Depends on how low you tune your box to also.
Post Number: 385
ported enclosure all the time but i'm thinkin of doing 1 18"Q like u or to fi x?
Post Number: 386
or two fi x's and i'm going to use it for sorround sound
Post Number: 11804
Hey, from my use and abuse, she's held up great. I don't push it at 80% volume at 80% gain either. At 50% gain I can't go above 40% volume or so without everything falling off my shelves. I found my "sweet" spot. Everyone's is different. (Enviornmental conditions).
