Explanation please.....subwoofer specs
-apem
Post Number: 16160
i hear many saying you should tune your box to around the fs on your sub.
explain this to me.
my sound splinter rl-s has a fs of 30.9.
the recomended tuning freq for a ported box is 24hz. that is way off.
lets hear some explanations or theories to why this is.
Username: Th3pwn3r
Post Number:...
Post Number: 6307
Username: Th3pwn3r
Post Number:...
Post Number: 6308
I'm deducting 16,159 posts from your post counter.
Username: Kravenblood
Ohio Hmmm
Post Number: 353
thats the ported freq where the sub will have the best flat response through out the freq range i think thats what the website says or did say
-apem
Post Number: 16162
no rob. its not for me. i just wanted to see what people think about that.
Username: Jesse59672
OKLAHOMA
Post Number: 836
because if you tune something at say 24hz, it isn't going to reach it's best response at 24hz. It's going to be "louder" at 3-6hz over it's tuning frequency.
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 4955
"no rob. its not for me. i just wanted to see what people think about that."
right chad. and i just want to see what people think about a quantum singularity. But i know what it means.
Username: Nd4spd18
Northwest PA
Post Number: 4651
I have found that what the manufacturer recommends is usually what works best, or close to it.
Having no manufacturer spec, I tune a few hz higher than the Fs of the sub, at the lowest. Have found that to be a safe guess when given no specs.
Username: Insearchofbass
Post Number: 7389
I understand the flat response idea but I also raise the question how will it SOUND below its fs like the hdc12 will play below its fs but tuned at 35 hz its not as tight as it should be
Post Number: 7390
it super punchy up on the higher notes though tuned at 35 hz
