18"AA ava enclosure size
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 1840
I just bought a 18" AA avalanche that i will be using for HT useage. I prolby use it 50% time for music and 50% of time for movies. I want to it go low.
I need to know he following:
1) What size to make the box
2) What to tune it to
3) How many square inches of port
space isnt an issue
Username: Jkidder
Gunshine , State Flawda
Post Number: 2530
7 cubes tuned to 30, 85 sq in
Username: Jkidder
Post Number: 2531
tuned to 28 i meant
Username: Snarl2004
Post Number: 1841
you dont think 28 is to high for HT use?
Username: Jkidder
Post Number: 2533
i wouldnt go under 25-26 and theres not much audible difference between 26 and 28
Username: Snarl2004
Post Number: 1842
sweet thanks
Username: Loudon
Post Number: 1934
sounds good to me .. i dont think what u got ur hansds on bro .. ur gonna shake everything in ur area lol what are u powering it with?
Username: Josh85
Gordon, PA
Post Number: 36
Nice sub. Good luck with it.
A pic is worth 1000 posts!!
Post Number: 10976
Snarl, you have what I've been searching for. You better post pics and a vid if possible. I've GOT to see this baby in action lol.
Username: Insearchofbass
Post Number: 7058
Just a thought you could try sealed and hit whatever note you want... you know for movies that hit below 20 hz
check here for a list of movies
http://forums.audioholics.com/forums/archive/index.php/t-14279.html
Post Number: 7059
heres a better link to movies under 20 hz
http://forums.audioholics.com/forums/showthread.php?t=14279
Username: Snarl2004
Post Number: 1843
im powering it with an infinity plate amp 500rms but when i get more money in getting a dayton plate amp 1000rms.
when everything gets all hooked up ill make a movie of it for sure
so do you think i should do sealed or ported? i was thinking ported just becuase i htought it would get very loud in the 20-30hz range. opinions?
Post Number: 7082
Thats up to you. It depends what you want out of it. But ported will be louder. I was just showing you some movies can go below 20 hz and wanted you to have a chance to set up for the thrill if you wanted to.
Username: Snarl2004
Post Number: 1844
i know some subs like dd and aq and some fi subs dont reccomend putting subs in sealed boxes. is it like that for the ava or is it whatever you choose?
Post Number: 7083
I was just guessing it could go sealed ...but sorry if im wrong
Username: Snarl2004
Post Number: 1845
o im just curious. im actually kinda interestd in making it ssealed but would still like other opinions
Post Number: 7084
give him opinions guys ported or sealed (smiles)
Post Number: 10981
P o r t e d.
Username: Jkidder
Post Number: 2539
any sub can go in either. i had my 3512 in sealed and sounded pretty tight. really doesnt matter. that ava is a beast... id go ported
Username: Hdubb
Team Revolution
Post Number: 2774
ported tuned crazy low 10cubes sounds good.
Username: Cenus
Ohio
Post Number: 3848
you can go sealed but you'll lose a lot of low end output espically wiht only 500wrms, if it was me i'd go 8cf tuned to 20hz, since most subs can go around 5-10hz under tunign with out damage and since the fs of the ava is 16hz and below that impedance rise is very high you shouldn't have to worry, although tuneing that low won't really do well on music other than rap, so rock or anything in the 60+hz range won't have much authority.
Username: Snarl2004
Post Number: 1846
my home speakers have 6"subs in them i will use as mids
Post Number: 7097
how about this solution how about a swappable port one for 20 hz (for movies) and one for the music tune you want
Username: Snarl2004
Post Number: 1848
hmm thats a possibility
Username: Snarl2004
Post Number: 1850
So i think im gunna do:
10cu ft
tuned at 24hz
85sq" of port
sound good?
Username: Th3pwn3r
Post Number:...
Post Number: 5723
"if it was me i'd go 8cf tuned to 20hz, since "
Same.
Post Number: 7126
yeah do 20 hz man and do the swapped port idea
Username: Jkidder
Post Number: 2573
how about a specially designed bandpass box....
Username: James1115
Use a simple...
Post Number: 10529
that sub is capable of doing 14hz, for HT that is AWESOME! go sealed at least 10cu/ft and throw 1000 watts at it if you can:-) for HT it doesn't matter that you can only hear to 20hz+/- it's the effect at 15hz when the whole room shakes that makes it lifelike:-) Chad used to run 2 18's in his HT set-up in a 20cu/ft enclosure sealed.
