Are alpine type R components musical?
Username: Mj23dynasty
Harrisburg star city, Pistolvania USA
Post Number: 116
i was reccomended tp get alpine type r comps over the infintiy kappa perfects 6.5"s and i was reading that those comps (alpines) are good for bass but i want some comps that will be musical and sound good on high notes because i will have enough bass coming from the BL"s and the 6X9" in the back i was also reading about PG comps idk which 1 to go with because ive never heard any of them ive heard the infinities on you tube but thats it. any help?
Username: Nyyfan13
Fi SSD USA
Post Number: 6886
find a shop close to you and listen to them. chances are there is a shop that carries the type rs and is real close to you.
Post Number: 118
Well thy sound different in the store then they do in the car.
Username: Adddisorder
Palm Beach, Florida
Post Number: 5441
go to best buy they will probably have both, even if they arnt in a car it will still give you an idea
Username: Shade
Moxee, Wa U.S.
Post Number: 460
i was happy with my R comps 6.5's, they are active, BUT now that i've had them for a while, i keep wondering of the Infinity Kappas would have been better....but then again i'm never satisfied
Username: Loudon
Post Number: 1932
kappa tweeters tend to be harsh to the ear ... alot of customers of mine have stated that in their reviews of the speaks
Username: Spivey17323
Dunellen, New jersey United states
Post Number: 829
i like my kappas. pretty damn good for what i paid for them
