Pioneer Avic-N2 Navigation Disk
Username: Bobsim73
Sewell, NJ USA
I have a pioneer avic-n2 in which I removed to install some additional equipment in my truck. When reinstalling the unit, everything works except the navigation. The unit is stating I am not using the appropriate disk. I am using the same disk I have always used with the system. I used the reset on the front, but still nothing. Does anyone have any suggestions on how to correct this or how to do a full reset in order to use my navigation again?
Username: Kpa2727
Post Number: 693
i never used this system but try disconnecting the power for 15 - 30 min let it's memory go dead then re connect see if it all goes back to normal.
