I think i have made up my mind....
Username: O0airjordan120o
MN US
Post Number: 134
i think im going to buy an 18 inch Fi BTL and power it at 1500 watts until i get a new alt. to put into it then power it at 2000. im going to put it into a 5 ft3 box ported to 33hz. wat do you think?
Username: Ctmike
Ct.
Post Number: 5343
i'd give it more power. if that's what you plan on giving it, i'd go with a bl with the bp options.
MN US
Post Number: 135
also i noticed they have quite a few options on the site... which ones should i go with?
MN US
Post Number: 136
i want to power it at 2000. it will only be 1500 untill i get a new alt.
Username: 420alldaylong
Post Number: 2740
Nick
A fully loaded Fi BL 18" will shine on the power you mentioned above.
ctmike
I don't think the Fi BL have the bp options.
Username: Adddisorder
Palm Beach, Florida
Post Number: 5321
nick 1500 to 2k isnt much of an upgrade, only 25%. also 1.5k on a stock alot is ALOT of current. and 2k isnt much for a btl.
Username: Hurricanebr1an
Western Burbs of Chicago, IL Usa
Post Number: 177
"ctmike
I don't think the Fi BL have the bp options."
yuh the option isnt listed, but could it be special ordered perhaps?
MN US
Post Number: 137
ya its not much power but thats not guna make a difference is it? i want the BTL so i can have room to expand. and i only want to power it to RMS cus i dont want to blow nothin.
Username: Tatonka
-[Team Audib...
Post Number: 965
Go for it Nick. But if it doesn't satisfy you, add more power
