Enclosure tuning help...plz
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 1659
4 ft^3 net
Vent:
16" Wide
2.5" Tall
30" long
40 sq" of port
i got 28 hz is this correct?
Username: Logan__tille
Team Revolution
Post Number: 8953
No, It needs to be 27.96 inches long to be 28hz.
At 30 inches it will be 27.183hz.
Ha but you wont notice a difference.
Username: Snarl2004
Post Number: 1660
thx logan...
like how do you figure out what its tuned to to decimal places. If i knew then i wouldnt have to ask every time i make a ...is there a program you use or an equation?
Username: Rovin
4 10 Pioneer...
Post Number: 12197
http://www.carstereo.com/help/Articles.cfm?id=31
Username: Snarl2004
Post Number: 1662
thats what i used to get the rough length i stated above but i was wondering how you be exact or how logan was doing it
