Advice please. Adding a second sub...
Username: Pike110
TC-Sounds LMS 5400 18, Indianapolis...
Post Number: 406
I wanted to add a second sub, I have a 13w7 and I just got a new eclipse ti 15". I just don't know which way I should go. I have a ss pca-2000 and a rockford t40001bd, so power shouldn't be problem. Let me know what you think. I am going for sql, I thinking I can't go wrong either way.
Username: Redliner
Wilmington, Ma
Post Number: 3944
wait so do u want have both subs going at the same time cause the above is kinda confusing
cause it wouldnt be a good idea to go with both. Most likely you wont know how to cross the frequencies right and it would sound horrible.
Username: Pike110
Post Number: 409
No, both are running in single sub set ups. I know not to run two different subs. I just wanted to add a second sub so I would be running two 13w7's or 2 eclipse ti's. Just can't decide which one to go with.
Username: Redliner
Wilmington, Ma
Post Number: 3947
oh ok i would say the 2 ti's
Username: Insearchofbass
Post Number: 6495
why would you get rid of a 13w7 for a eclipse ti
Username: Redliner
Wilmington, Ma
Post Number: 3948
i like bigger subs better not saying the ti for the w7 but because the ti is a 15 i like it better than the 13"
but they both play pretty equally so it all depends on which one u like more
Username: Pike110
Post Number: 410
I'm not going to get rid of the 13w7, just going to add another one or another 15" ti.
Username: Skibum12189
Cleveland
Post Number: 1682
i heard a 2 13w7s in a small car and i couldnt breath, yet it sounded amazing...i'd go 2 w7s
Username: Denali_on_22s
Im just light up my......
Post Number: 2825
they dont make ti's anymore so you would have to buy your second eclipse ti used i think
Username: Rovin
4 10 Pioneer...
Post Number: 12190
i prefer JL ....
