Gold Member Username: JohnfiacA-ToWn, 9515 thumpin... What u bumpin? Post Number: 3482 Registered: Mar-06 | SD2.510-D4(10s) 4 of those or 3 12" Alpine X's on Zx2500.1 sealed.... looking for SQ and Output for daily in SEALED i only have about 1-1.5ft per sub if 10, maybe 1.75ft tops for 12's |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 4440 Registered: Jul-06 | I'd have to say the Alpine...just because too many noobs on here have the SD2.5s,man do I hate those subs.Are you set on those subs though?What about a couple SI Mags in there?You could also copy Chad's setup ![]() |
Gold Member Username: InsearchofbassPost Number: 6286 Registered: Jun-04 | my bro sealed his audioque 2.5 12 sd with a plate over the port and he said it was very tight sealed ps he hit 136 db with it sealed on the 600 rms compared to 142.4 db ported 35 hz tune....but I dont no anything about the alpine type x's |
Gold Member Username: InsearchofbassPost Number: 6287 Registered: Jun-04 | Rob just curious why you hate the 2.5 audioques |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 4443 Registered: Jul-06 | You could also stick with DD and run 3512s and feed about 12-1400 RMS a piece.That would slam i don't think you have the charging for that Kicker amp though...what do you have for an alt and wiring? |
Silver Member Username: BoomtankRochester, NY USA Post Number: 349 Registered: Oct-06 | sean he hit 142.4 dB with only one 12 AQ 2.5sd? not bad how big was the box? and in what kinda car? |
Gold Member Username: InsearchofbassPost Number: 6288 Registered: Jun-04 | 2.50 cubic feet net and its in a 2006 jeep liberty |
Silver Member Username: M0nkeyman692Post Number: 302 Registered: Feb-07 | personally i like the 2.5s.. they are very loud for their size. but if your going for sq then i would steer away from them they dont really sound the best. or at least there are subs that sound better. im not saying they dont have any sq |
Gold Member Username: JohnfiacA-ToWn, 9515 thumpin... What u bumpin? Post Number: 3483 Registered: Mar-06 | Rob, i only have a 150A alt in there now its stock, and i have a brand new battery under the hood not sure what specs tho, then a yellow top in the rear with about 14ft of 0gauge kicker hyperflex connecting the alt\battery to the rear battery so it should be able to pass a good 250A on that short length. Im going to eventually upgrade to maybe a 200 or 300A but thats later on... i dont bang to long so i ussualy have the power for the amount of time i do.. and "2.50 cubic feet" WAY to big for me to get 3 12s in my trunk with boxes that size LOL |
Gold Member Username: JohnfiacA-ToWn, 9515 thumpin... What u bumpin? Post Number: 3484 Registered: Mar-06 | Can i get some links for the MAG's and RL's |
Gold Member Username: 420alldaylongPost Number: 2586 Registered: Sep-06 | www.stereointegrity.com/ www.soundsplinter.com/ |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 4487 Registered: Jul-06 | The Mag and RL-S will cost you a bit more than what you were looking at before but I'm sure it will also sound substantially better. |
Gold Member Username: InsearchofbassPost Number: 6317 Registered: Jun-04 | and "2.50 cubic feet" WAY to big for me to get 3 12s in my trunk with boxes that size LOL sorry killa I was answering eddy |
Gold Member Username: InsearchofbassPost Number: 6318 Registered: Jun-04 | and just givin you something to go by for a sealed application sq wise with the 10's |
