Where is "Q button" on Kenwood X617?
Username: Paganmama
Harleysville, PA United States
I've somehow messed up my in-dash Kenwood X617 so that it's continually cycling through its present sound settings -- "Scan Flat, Scan Jazz - Scan Top 40" etc. My manual says, "Each time you press the Q button, the preset sound setting switches." Nothing on the controls is labeled as the "Q button," and I can't figure out how to make the cycling stop. Any suggestions?
Username: Kpa2727
Post Number: 636
a buttons prob just stuck, try pulling the face plate off and re attaching it. slso not a "q" button it's prob a typo it's known as a "EQ" button aka eqalizer and it's prob stuck.
Username: Kpa2727
Post Number: 637
actually i found it, if u look closely it is a q button.
