Boss R850 Amplifier.....what makes it bad?
Username: N30
Here are the specs:
Boss R850 Car Audio Amplifier
Mono Channel, 400 W x 1 (RMS), S/N Ratio: 105 dB, THD at Rated RMS Power: 0.01%
Q: If the S/N and THD are fairly respectable, why is Boss considered a poor choice? Especially since it was purchased new for $62.90.
Username: N30
P.S. The mad smiley was unintentional. I have no brand loyalty dispute.
Username: Glasswolf
Post Number: 1153
build quality.
they are poorly made.
specs are misleading.
you get what you pay for in this case, which is a poorly made, fancy looking amp that will most likely fail in short order.
Username: N30
That makes sense. I guess if he (my son) gets a year out of it (the warranty period), then perhaps his funds will allow an upgrade. He is just trying to do to much to quick...
What could he expect to spend to achieve those specs plus reliability?
Username: Glasswolf
Post Number: 1154
600W x 1 @ 2 Ohms
JBL BP600.1
$210 USD
