Good enough for now?
Username: Doconpoint1
Park Forest, IL
Post Number: 8
Are these numbers decent enough to power 2 4ohm dvc Kicker Cvx 12s.
A two channel amp.
2 x 600 Watts RMS at 4 Ohms
2 x 1200 Watts Max at 4 Ohms
1 x 2400 Watts Max at 4 Ohms Bridged
2 x 1000 Watts at 2 Ohms RMS
Electronic Crossover Network
Bass Boost Circuit
Variable Phase Shift Control
2 Ohms Stereo Stable
Anti-Thump Turn-On
Soft Turn On/Off
High & Low Level Inputs
Blue Light Illuminated Crossover Control
Power & Protection LED Indicators
Advanced Protection Circuitry
Bass Boost Remote Control
T.H.D: 0.04%
S/N Ratio: 90dB
Channel Separation: 65dB
Frequency Response: 15Hz- 35kHz
Dimensions: 10.47"W x 2.46"H x 19"L
I didn't put the brand because i'm not interested in whether someone thinks it's crap and i should spend more. I'll upgrade the quality later.
Username: Loc_out
Santa Ana, Ca Resonant Eng...
Post Number: 888
Simple answer no. Each sub needs 750rms you need an amp that puts out 1500 rms @ 1 ohm. If money is an issue, look into hifonics amps.
http://cgi.ebay.com/HIFONICS-BXI1606D-1600-WATT-SUPER-D-CLASS-MONOBLOCK-AMP_W0QQ itemZ150141341661QQihZ005QQcategoryZ64570QQrdZ1QQcmdZViewItem
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1232
you DO NOT need a 1 ohm mono, a 2 ohm stable stereo is fine for 2 4ohm dvc subs.
that is a bit much power, if you do use that amp, keep the gains way down. CVRs are rated for 500w rms i think, and you'd be setting them up on double that which if you dont know what you're doing, you would be setting yourself up for having a pair of blown subwoofers
Hfl, Ny Usa
Post Number: 1233
oh and they dont NEED 750w rms. it all depends on the box you have. the bigger the box, the less power required to push the sub to its mechanical limits. power ratings are generally thermal. but they are guidelines mostly. you dont NEED to be exact and you dont NEED a mono amp at 1 ohm.
just be careful with your gains. dont use them as a volume control PLEASE
just curious, what amp did you have the specs for? that 2 channel in orig post
Username: Loc_out
Post Number: 890
You did notice those are CVX nor Cvr right?
Hfl, Ny Usa
Post Number: 1240
yeah i saw after that. but my points still hold true. they dont need exactly rated power to reach mechanical limits nor does overpowering them mean they will blow.
like i said, it all depends on the box you have them in
Username: Loc_out
Post Number: 891
Your point does stand if you knew the size of box he intends of using. Without that info you're under powering them. We should find out what type of box?
Hfl, Ny Usa
Post Number: 1242
theyre dvc 4 ohm, hes overpowering by 250w rms
Park Forest, IL
Post Number: 12
It was a lanzar amp. And i figured since i've seen a lot of people say that generally budget amps don't put out what they say, that the 2 x 1000 rms would be a lil closer to the 750 if not lower. And yeah i've looked at many forums and in doing so i def know not to use the gain as a volume knob. Also it's a ported box. I can't remember the volume, but i think it was like a lil over 4 or so.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4788
bad amp, lanzar only makes good monoblock amps. If i were you i'd grab an optidrive 1400d, i'm telling you cuz i own a lanzar 1800d
Park Forest, IL
Post Number: 13
thanks, but i'm gonna go a certain route for now.
Username: Killswitchjd
Post Number: 642
lanzar sucketh
Park Forest, IL
Post Number: 14
well the debate isn't if i think they suck or not. i never said they were good, and i know how most feel about them. but if you fill like paying for me an amp of your choosing feel free. But thanks to those who've been constructive in trying to help me.
