Need opinions for a 1000-1200 watt amp...
Username: Skateguy92
Well im looking at getting a 1000-1200 watt amp for a couple type R 12's....
I was looking at the Ed Nine.1 and I read a bunch of good things about it, but recently ive been reading alot of bad things about it so im kind of weary about buying one.
Any other suggestions? I want a NEW amp... I would like a warranty and I dont really want to spend more than $350-$400.
Thanks!
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4799
kicker kx 1200.1
memphis prd 1000.1
Sundown 1000d
orion 1200d
many others...
I just want something I can hook up and not worry about it crapping out or over heating... Any personal suggestions?
Its just going to be a daily amp, no competitions or anything.
Username: Imalik
SD2.5......ED9.1=Boom, New Jersey Audioque...N...
Post Number: 461
What are the bad things that you have read about the 9.1?
Its been mixed opinions I guess.... Ive read that they are very unefficient, that many people have had them crap out (even though it does come with a 5 year warranty), and things like that. But then again thats just what I have read... Ive never had any experience with them personally.
Username: Imalik
Post Number: 463
Ok...not too sure where they get that from, amp is very efficient. If you set your gain correct, the amp will do a great job on your R's
Username: Audiostud
Stillwater, OK USA
Post Number: 71
I run the ed nine.1 on my 2 R's. Sounds great...and no problems. Do it
