Need a good 4kw amp at either 2 or .5 ohm any ideas.
Username: Safe_cracker
Chicago, IL US
Post Number: 2990
Anyone have any ideas, maybe one you have seen on another forum or such? I am looking for an amp with this as a potential but will probably dial it down for daily. Thanks...Polo.
Username: Jkidder
Spring hill, Florida Usa
Post Number: 979
how much money r u trying to spend?
Username: Theweasel
Steamboat springs, Colorado U.S. of A
Post Number: 849
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3174
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5565
Username: Theweasel
Post Number: 851
2 of these
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3195
Username: Cenus
Hicksville, Ohio
Post Number: 3331
just go all out and get an adassa warlord, just have fun paying for it.
Username: Jkidder
Post Number: 984
rob that ma audio amp wont put out anywhere near 4k at 2 ohm. more like 3400
Username: Jkidder
Post Number: 985
dd z1a or mmats makes amps that are stable at 1/2 ohm. i kno they make a 3500.05 i just dont kno of anything higher than that.
Chicago, IL US
Post Number: 2992
Rob, that was an idea I had but was steered more towards a XXX-6500 because seems that most people don't have the electrical for them so they are seeling for $600-$750, it may not get the full 6500 only on 16V but it will do at least 3500 at 2ohms while saving some SQ doing it. I'm trying to stay in the $750 max range so the unit will probably be used. Polo..
Username: Loudon
Post Number: 1346
see if u can find a ground zero 6000 ... same board as the xx6500d ... ive seen em go for 500-7000 ...
does 3700-4000 at 2 ohms at 14 volts
Username: Cenus
Hicksville, Ohio
Post Number: 3332
for that much you might find an used IA40.1 or maybe an used american bass 400.1 but those are hard to come by and for under $1000, but they are worth it theres ppl who run .22ohms daily with no problems.
Username: 420alldaylong
Post Number: 2222
Polo
Realm of Excursion
For sale section
Hifonics XX Colossus II
I think $450
Username: Skibum12189
Cleveland
Post Number: 920
.22 daily holy shhiit
Username: Jkidder
Post Number: 988
guy on ca.com is sellin his ia40.1's for 800 he has 6 i think?
Chicago, IL US
Post Number: 2999
http://www.caraudio.com/forum/showthread.php?t=224677
How about this one, good deal? Polo..
Username: Jkidder
Post Number: 998
o yea. Z1 is sexxxxy.
Username: Th3pwn3r
Post Number:...
Post Number: 3556
I'll sell you my Memphis 4KW for 650 if you want to pick it up.I've heard that they can handle a .5 ohm load as long as you have the charging to back it.You should also see quite a bit of power out of it on 16volts.
Username: Tremor1127
Team Fi Car Audio [:-]
Post Number: 1869
.22 ohm daily?!
hey, american bass amps will do .5 daily but im not sure if they have a 4kw amp... they have fairly priced big amps though...
Username: Cenus
Hicksville, Ohio
Post Number: 3334
ya but thats not figureing in box rise or anything, so the amp is probally seeing a .3-.5ohm after box rise which is still very impressive for daily.
Username: Mike11202
Sewell, NJ US
Post Number: 789
i dont know about this brand but maybe somebody here does?
strap 2 of these together
http://cgi.ebay.com/PowerBass-ASA-2000-1-D-4-000-watt-mono-amp-1-ohm-stable_W0QQ itemZ220127619046QQihZ012QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Southernrebel
Post Number: 5068
Hell...my 20.1 takes 0.35ohm daily like its nothing.
Try that 40.1 :-)
Post Number: 1878
yes, IA was the other brand i wanted to say would take .5 easily...
Username: 04redmach1
Columbus, GA USA
Post Number: 1022
Polo, shoot me an email, I have a few amps that might do you justice.
Kevin
lowhz01@yahoo.com
