2 Ohm or 4 ohm DVC?
Username: Kicker101
Alberta
Post Number: 118
Whats the diffeerence?
Whats better?
Which has more wireing options?
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 1377
depends what ur wiring it to. If you only have one sub and its DVC but one has 4ohm coils and the other has 2ohm coils it just depends on the amp ur using. if you want to wire to a 2 or 8ohm load get the DVC 4ohm sub. If you wanna wire to a 1 or 4ohm load then get the DVC 2ohm sub.
u can use this:
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Username: Logan__tille
Team RevolutionImortal Box ...
Post Number: 8095
What amp do you have?
Username: Kicker101
Alberta
Post Number: 119
well im gettin the kicker L7's (four or two ohm) i havent decided yet..thats y im here? i dont have an amp yet either? suggestions...
Post Number: 8102
Dual 2ohm and a kicker zx1500.1
Post Number: 8103
Or, Dual 4ohm and kicker kx1200.1
Username: 420alldaylong
Post Number: 2024
Kicker L7 8" dual 4ohm-Kicker ZX400.1
Kicker L7 10" dual 4ohm-Kicker ZX750.1
Kicker L7 12" dual 4ohm-Kicker ZX750.1
Kicker L7 15" dual 4ohm-Kicker ZX1000.1
I hope this anwser your question. And wire it this way.
http://www.cardomain.com/shop/wooferwizard.pl?num_of_subs=1&impedance_of_subs=4o hm_dvc&x=140&y=11
Username: Kicker101
Alberta
Post Number: 120
im starrtin to get the hang of it but im still confuzed as hell?????
Post Number: 2025
John kicker
How much are you paying for that L7?
What size are you looking to get?
Username: Johnfiac
A-ToWn, Kingkong ain... I got Chuck ...
Post Number: 3165
Ummm... logan why DVC 2ohm and Kicker 1500.1? run it at 4ohm?
Post Number: 8113
How about 2ohms?:-)
