Box tuning hz?
Username: Spivey17323
Dunellen, New jersey United states
Post Number: 122
how do u know what your box is tuned to and how do u tune it? pretty confused
Username: Oglejust
Post Number: 2029
tuning is dependent on the length, width, and hight of the port and the amount of air in the box :-) any help after this will be done by others
A pic is worth 1000 posts!!
Post Number: 7515
You have to determine tuning BEFORE construction. It's a combination of enclosure volume and port(s) lengths and widths. Sealed is a good choice for beginners. There are many box/port tuning sites out there. Which will follow.
Shortly.
Post Number: 7516
I posted mine and Justin's bumped me off. You turd.
Post Number: 123
oooooooo ok. thanx
Post Number: 7517
The most common site for slot ported.
http://www.subwoofertools.com/forum/ported-box.asp?Ew=34&Eh=17&Dia=9&Xmax=26&Vd= .17&NumW=1&Vb=3.5&Fb=33&Qts=&Vas=&Fs=&CE=0
Another good place for vent lengths and widths.
http://www.carstereo.com/help/Articles.cfm?id=31
A good all around general site.
http://www.diysubwoofers.org/
