Is 2 type r's in a box for 310 a good price or wat would you recomend
Username: Solid8447
Post Number: 20
is 2 type r's in a box for 310 a good price or wat would you recommend
Username: Jblanford
Post Number: 1434
thats not that bad of a price at all
Username: Skibum12189
Cleveland
Post Number: 738
brand new or used?
Username: Solid8447
Post Number: 22
used
Username: Logan__tille
Team RevolutionImortal Box ...
Post Number: 8086
What size?
Username: Solid8447
Post Number: 23
12's
Post Number: 8087
Depends on the box.
Username: Sheriff
Post Number: 527
Are you talking about the ones from Charlie Ried?
Username: Hdubb
Farmington, Nm Usa
Post Number: 2090
thats not a bad price but it isnt great. last tim e i checked htye type r they were like 159.00 so its really not they great.
Username: Cried
Erie, PA US
Post Number: 350
well you can get type R's 2 new for $250.00, and the box is custom 3.5 cubes 35Hz carpeted with terminal cups and flared ports. I could sell it for probably $200.00, so $310 is a steal anyways, and if shipping is free then you're good.
