Which dual voice coil subs are the best.
Username: Scott_shumpert
Anderson, South Carolina United States
Post Number: 9
I need to get two new subs and i'm thinking about dual voice coil subs. I need some advice on which ones are the best.
Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1903
most subs are dual voice coil....theres lots that are good....depends on what amp you got to decide what will work best. How much u lookn to spend? and how much power you runnin?
Username: Johnfiac
A-ToWn, Kingkong ain... I got Chuck ...
Post Number: 3115
LMAO such a noob question DVC doesnt mean anything in picking a sub its just an option mainly so the sub can have more wiring options, also to increase the power handling.
Username: Logan__tille
Team RevolutionImortal Box ...
Post Number: 8066
Alpine Type R!!!
Username: Tatonka
Post Number: 431
FUNKY PUPS!
SQ IS THE ONLY WAY
Post Number: 13595
killa there are some single voice coil subs too. like the sound splinter rl-s is a single vc.
don't call someone a noob just because they asked a question.
scott how much power are you planning on using? how much are you willing to spend?
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 1355
depending on the voice coils on the sub(s) it changes at what ohm load it puts oin the amp.
For example if you are getting 2 subs and a 1 channel amp to get the power from the amp at 1ohm you would need dual 4ohm subs. To get power from the amp at 2 ohms u would need dual 2ohm subs.
Heres a link to a wiring diagram that shows how to wire the subs and what voice coil configuration for the subs you should get so you can choose which subs to buy:
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Username: Oneracistguy
TWO EGG, FL USA
Post Number: 743
killa u was a noob once too... this guy is tryin to get help so help em dont call em names
Username: Johnfiac
Post Number: 3123
Chad i know subs are available SVC, QVC to... it just sounded noobish "which ones are best" almost EVERY major sub is DVC and some available in QVC so it really cant be answered without a budget
And re-read that if you think i called him a noob....
"LMAO such a noob question"
Username: 420alldaylong
Post Number: 1972
The ones that fit your amp load.
Username: Basssquared
Kansas
Post Number: 628
GREAT phucking answer Joey
Username: Hdubb
Farmington, Nm Usa
Post Number: 2086
well the lmt tech from tc sounds is svc and that is a damn good sub, but you have to find an amp that puts out that much power at 4ohm
Username: Hdubb
Farmington, Nm Usa
Post Number: 2087
and i remember when killa was a noob, a long time ago. hell i remember when i was a noob too. and as far as subs to amps it is easier to start with your amp then your subs, when you already know what you amp can do you just amtch the sub to it. imo
