Sub wiring?
Username: Stamant
LA, FL USA
Post Number: 255
Will upgrading the speaker wires from the subs to the amp help. I currently have 16 gauge. Should I use a smaller gauge wire? I have two 12" BMs and a NINe.1.
Username: Dakangofkrunk16
Post Number: 356
Usually Thicker Speaker wire can help..Like 10awg..some people do overkill and get 4awg but i find there to be nothing rong with overkill
Username: Trey4sports
Post Number: 1275
no audible difference between 16 and 10, but i reccommend u get 10 ga like dru said bc it has slightly better current capacity and wont het up as quite. however you wont hear a diff
Post Number: 1276
*wont heat up quite as quick*
Username: Nd4spd18
Southeast PA
Post Number: 2746
" Should I use a smaller gauge wire? "
You mean larger gauge wire. Lower number = larger. And no it won't make a difference with that amp/subs.
Username: Theivan
Dawson Creek, British Colu... Canada
Post Number: 108
not sure, im only runnin a 500 wat amp to two subs and when i put my capacitor in i had to switch to 4 gage cause the grouds melted lmao. go to 4 gage and be safe, it will last forever and when you upgrade your system you dont need to buy new wiring and reinstall all of it....
Username: Nd4spd18
Southeast PA
Post Number: 2770
^^^^ did you even read the thread
We're talkin about speaker wire not power wire
Post Number: 361
"im only runnin a 500 wat amp to two subs and when i put my capacitor"
Capacitor FTWM For the wast of money
Username: Jkidder
Spring hill, Florida Usa
Post Number: 726
haha nice dru
Username: Stamant
LA, FL USA
Post Number: 256
Ya, ms. I meant a larger gauge wire.
A pic is worth 1000 posts!!
Post Number: 6909
I know I went overboard with my speaker wire for both my subs. 15" Mag and 18" Q. I used 10ga for both. My run was short and I only had 1000wrms. I didn't care. I wanted absolutely zero signal loss and heat build up. For my cost it was an easy decision. If you were running 20-30' of wire well....your call.
Username: Surferdude9371
I like my beat down low
Post Number: 134
never hurts to upgrade the size i upgraded system without upgrading the wire and it melted in my truck then shorted not fun.
