Man i just fu@ked my Q up!!!! :-(
Username: Thomas_g
NM
Post Number: 2314
I must of overexcurted it yesterday. :-(
I hope i can fix it by soldering it.
Username: •cam•
Post Number: 305
shitty man. yeah you should be able to solder it.
A pic is worth 1000 posts!!
Post Number: 6481
Aw sh1t. Both leads snapped off? Sux. Big time.
Username: Hgihkcin
Lincoln, NE
Post Number: 177
they might be too short now, talk to scott about getting a new set sent to you
Username: Imalik
SD2.5ED9.1=Boom, New Jersey Audioque...N...
Post Number: 303
Ouch...
Username: Thomas_g
NM
Post Number: 2315
It does suck!!I tried soldering it but it is too short and the comp is coming up next month so i got to hurry up. Only one tore, but the other 3 are like ripped almost torn. Im thinking since this sub fu@ked up its not gonna perform 100% so i might have to sell my Q's and go with the premiers now..... I dont think scott would do anything about it.
Username: Safe_cracker
Chicago, IL US
Post Number: 2819
Overexurted? That is BS, in the world of subs and bumping the only thing to stop excursion is the backplate, lol! I would send it back for warantee repairs... JMHO...Polo.
Username: Thomas_g
NM
Post Number: 2317
lol i dont know thats just what i thought,if it only happened to one of the Q's, and they are in the same box with the same power, wouldnt the same thing of happened to the other one??
Post Number: 6484
My guess is the leads on that sub were cut a tad short b4 applied. Replacing them yourself could prove more damaging than good, possibly voiding any warranty scott would honor. Definately contact him b4 you do ANYTHING.
Username: Thomas_g
NM
Post Number: 2318
Check it out http://www.soundsolutionsaudio.com/forum/index.php?showtopic=8656
Post Number: 6487
Looks like he'll hook you up with the parts. Give him a shout.
Username: Showrides
Hartford, CT USA
Post Number: 614
Good luck getting it fixed. It won't be easy to do, but if you take your time and go slow you should be able to do a very good job. And the sub should perform exactly the same afterwards if you do a good job.
And make sure to scrape off any exsisting glue!! If you don't the new glue won't hold very well at all. That is the best advice I can give.
Username: Showrides
Hartford, CT USA
Post Number: 615
Chicago, IL US
Post Number: 2820
I was reading that other people were thinking it was to much power? On another note how often do you see broken tinsels on Treo or DD subs with them interwoven into the spider? Polo.
