Help me plz...i cant figure this out
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 969
Alright i tried to set my gain today...
I turned all my eq's off. I turned HU to 3/4 of volume and gain down. I got a DMM and set it to the 200~ setting. I played a 50hz tone. I may be dumb or something but wut do i do next. I put the positive wire from the DMM on the positive post on the amp. I put the negitive wire from the DMM to the negitive post on the amp. When i did this my subwoofer was still connected...does this matter? Anyway when i put the DMM on it only registered to like 5 on he DMM. Help plz.
Username: Nd4spd18
Southeast PA
Post Number: 1821
Disconnect your sub
Username: Snarl2004
Post Number: 970
do i disconnect the positive and negivtive wires from amp to sub then put the positive and negitive wires from the DMM on the positve and negitive posts on the amp?
Username: Nd4spd18
Southeast PA
Post Number: 1822
Yep
Username: Snarl2004
Post Number: 971
alright so i did it. on my HU i have bass setting i put to zero. i turned off the "loud" setting. on amp i turned off bass boost. the only thing is on my HU i have something called subwoofer level and on 0 nothing goes to amp and on 8 its all the way up. I set it when it was on 8. Is that what i was sposed to do?
Username: Nd4spd18
Southeast PA
Post Number: 1824
Ah ha that's the problem...... you want the sub level all the way up when setting the gain. If you set the gain with it turned down, the amp would clip when you turn it and the volume up.
Username: Nd4spd18
Southeast PA
Post Number: 1825
Oh wait, I misread that..... you did set it with it all the way up? You should be good to go then......
Username: Snarl2004
Post Number: 972
ya i left it all the way up. one last thing...
also when i set it the bass boost on my amp i set at about 5. when i pu tit on 0 i only got up to 27volts and i need 31. When i put my bass boost on 5 (out of 10) the gain was about 3/4 of the way up. As long as i dont turn up the bass boost any more and i leave it at 5 from now on i should be fine...right?
Username: Nd4spd18
Southeast PA
Post Number: 1827
That doesn't sound right......
- What amp is it?
- What HU?
- What ohms is the amp run at?
Username: Snarl2004
Post Number: 977
amp is Earthquake PH2000W/D1.1
HU is JVC KD-G320
amp runs at 1ohm
Username: Snarl2004
Post Number: 979
bump
Username: Nd4spd18
Southeast PA
Post Number: 1830
Well that HU only has 2 volt outputs (not so great), but something doesn't seem right here.
You say you turned the gain all the way up and still only got 27 volts? Are you sure the test tone is good, not an attenuated tone? That amp doesn't have a high/low switch for the gain anywhere does it?
Username: Snarl2004
Post Number: 982
i made the tune using a tone generator program. i made a video of me explaining it im uploading it to youtube now ill post the link here when its up. i dont see any high/low switch on the amp
Username: Snarl2004
Post Number: 984
^^^http://www.youtube.com/watch?v=vbqLU2S5NNs
heres me trying to et the gain
it worked i just had to put the bass boost at 5 outta 10 and then turned gain to 3/4 of the way and it was perfect
Username: Nd4spd18
Southeast PA
Post Number: 1833
May I suggest trying this tone just to make sure that's not the problem:
(right-click and save target as)
http://www.realmofexcursion.com/jmac/audio/0dB_wav_test_tones/50%20Hz.wav
Username: Snarl2004
Post Number: 985
dark now so i cant try but ill try it tomarrow after school
do i seem to b ding everything right in the vid?
Username: Nd4spd18
Southeast PA
Post Number: 1834
Ok I just watched the video. First of all loudness should be OFF.
Next, did you try turning the gain up more than 3/4 instead of adding bass boost? Cause with a 2 volt HU you're gonna have to turn it up pretty far, but you should never have to add BB to get the gain set right.
Username: Nd4spd18
Southeast PA
Post Number: 1835
^^^ Never mind that last part you said VOLUME was at 3/4.
It looks like you're doing everything right.
Username: Nd4spd18
Southeast PA
Post Number: 1836
Except for the loudness. Turn that off and try it again.
If it still don't work right, then I'll start to wonder if that amp doesn't do it's rated power?
Username: Snarl2004
Post Number: 988
well i still have stock alt and batt but it must put out close to the rated power cuz it does make the subs move full extension when the volume isnt all the way up. I have 2 SD2.5s
Username: Snarl2004
Post Number: 989
o ya and should the "loud" always be off or just wile i set my gain
Username: Nd4spd18
Southeast PA
Post Number: 1841
Definitely have it off when setting the gain, and I don't personally use it anytime. All it does is boost the bass and treble while leaving the midrange unchanged. If a system needs tuning, I use an EQ.
Username: Volfenhagking1600
15 SSD Wangin, Shawano, Wis... USA
Post Number: 622
Wouldnt you set everything on your head unit first and then tune your gain so you dont clip your sub????
Username: Jesse59672
OK
Post Number: 228
yeah ive never used loud on anything i've had how much is a dmm anyways? i set my gains by ear pretty much.. doesn't sound like anything is clipping but i'm not sure if im giving my sub the most i can
Username: Nd4spd18
Southeast PA
Post Number: 1853
No. You shouldn't be using bass boost or anything after the gain is set. The sub level on the HU should be all the way up, so that you can turn the sub down when you want, but not turn it up into clipping.
Then, if the system needs tuning, it should be EQ'd by first cutting certain frequencies, then boosting other if that is not enough.
Username: Nd4spd18
Southeast PA
Post Number: 1854
I don't get how people can install systems without even owning a DMM, lol. But you can get them for about $20 at any walmart or hardware store.
OK
Post Number: 230
what i did was turn up all of my settings and the volume as well and slowly turned the gain up until it started clipping then turned it back down lol
Username: Dakangofkrunk162
Post Number: 111
yea DMM should be rite next to ur Alan Renches and Screw drivers i got mine for like 15 dollers or so Got the smily face on that one Wal mart
Username: Snarl2004
Post Number: 1005
thanks for the help everyone...expesialy M.S.
i used the 50 hz tone u gave me and turned off loud and now its working good. Bass boost off and the gain is only a little over 3/4
and i think ill getthis alt within the next couple a weeks:
http://cgi.ebay.com/ebaymotors/220amp-Amputator-Series-Iraggi-Alternator-Chevy-G MC_W0QQcmdZViewItemQQcategoryZ33573QQihZ019QQitemZ7963120240
Username: Nd4spd18
Southeast PA
Post Number: 1889
No problem man
It was probably the loudness setting, I doubt the tone was bad but ya never know.
Username: Nd4spd18
Southeast PA
Post Number: 1891
BTW thats the exact same alternator I'm getting for my truck
Username: Snarl2004
Post Number: 1007
lol nice. wut kinda truck u got?
Username: Snarl2004
Post Number: 1009
bump
Username: Snarl2004
Post Number: 1010
bump damit
Username: Nd4spd18
Southeast PA
Post Number: 1895
1994 Chevy S10 Blazer. SUV really, but I call the old ones trucks cause they basically are an S series tuck with the back closed in. 4WD FTW (we need it in the winter in PA)
It looks kinda like this, except it is a 4 door, the 4 door ones are longer. Not an actual pic of mine:
1
