Wiring question, 2 x Dual 4ohm, 2 amps - 1ohm load each
Username: Impala63rag
DD 9512s , Orion d5000
Post Number: 722
I want to add another Orion d5000. I'm buying a H.O. alternator, and want the benefits from it. I have 2 dual 4ohm subs. Can the amps be rigged to run at 1ohm?
The forum isn't posting my thread.
Username: Ctmike
Ct.
Post Number: 3926
just checked the user manual and it said you cannot strap/bridge them.
Post Number: 723
Would a notice a big difference by adding another, and letting them run at 1700wrms @2ohm. instead of 2500 for both at 1ohm?
Post Number: 728
bumpage
Post Number: 730
feedback, ?
Username: Oneracistguy
TWO EGG, FL USA
Post Number: 548
sell the 2500d and buy 2 2500rms at 2 ohms or recone them and get them dual 2 ohms
Post Number: 732
Is there a good amp that will run 4-5k wrms?
Post Number: 733
Is this what it says? 5k wrms? Is it overrated, or a good upgrade?
Hifonics Goliath
http://cgi.ebay.com/HIFONICS-XX-GOLIATH-5000-WATTS-AMP-BRAND-NEW_W0QQitemZ290102 417350QQihZ019QQcategoryZ64570QQrdZ1QQcmdZViewItem
Post Number: 734
bumpage
Username: Ctmike
Ct.
Post Number: 3964
personally i can't see spending $1500 on hifonics. i'd try to get with spl or ben, think those are the two, while their selling stuff at crazy low prices. i know their selling memphis and kicker amps so you'll probably be able to get a pair of really nice amps cheaper than that hifonics.
Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1559
sell the 2500d and upgrade to a Memphis 4kw or 2 kx2500.1. Orion's aren't strappable so havin 2 wont help ya out much since you'll only get 900 watts more.
