2 ohm sub at 2 ohm??
Username: Ceoofdaroc4
Post Number: 143
Hey whats up I got a 2 ohm L7 and I got it wired 2 2 ohms at circuit city... the negative 1 voice coil doesn't even have any wires running thru it.... and the positve 1 has a wire coming from the positive 2 ... well u guys prolly kno what I'm tlkin bout thy have a 2 ohm sub wire to 2 ohms by not hooking up 1 of the voice coils is this safe or should I wire em 2 4 ohms bcuz my amp isn't 1 ohm stable
Username: Naledge503
Http://com4.runboard.c...
Post Number: 1260
No! always wire both voice coils. Run your amp at 4 ohms until you can get an amp that does the power you need at 1 or 4 ohms
Username: Livin_loud
No HTML in h...
Post Number: 1533
heres that amp you need
https://www.ecoustics.com/electronics/forum/car-audio/343091.html
Post Number: 144
No I I'm not getting new amps ill get 4 ohm subs if anything... and explain what happens if u run it like I said it has 3 voice coils hooked up and 1 not hooked up I had it like for maybe 3 weeks or so... wat could happen...
Username: Wolf_hound
Post Number: 158
Pics of how you have it wired? Also what kind of amp do you have
Username: Nd4spd18
Southeast PA
Post Number: 1324
DON'T DO IT. It will damage the sub.....
