Looking for a 1000 rms per channel
Username: Nascarfan
Tallahassee, Florida
Post Number: 32
Want to buy a 1000 rms per channel amp, so basically I need a 2000 watt amp. I want to run 1000rms to each 12" sub.
Thanks Chris
Username: Van_man
Boston South, MA
Post Number: 2281
Heres a break down on some decent amps. Some are junk, some are great. But its a starting point.
Whats your budget and subs voice coil config?
http://www.lightav.com/car/amps/poweramps.html
Username: Mash4kash
Lafayette, LA
Post Number: 74
at what ohm
Username: Rovin
My 1 12 Atom...
Post Number: 11035
sub model no ? ......
Username: Killswitchjd
Post Number: 350
figure he wants a 2 channel 1000x2 rms at 1 ohm or 4 ohms
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4315
post subs, RMS and voice coil config
Tell us a budget
Do you have a good charging system?
Username: Nascarfan
Post Number: 43
Sorry I was away, I have Alpine Type R's 12" dual voice @4 ohms, max watt rating is 1500 with a 500 RMS, I would like to have enough power to run both subs in sealed box, and have plenty of power for backu-up, any suggestions or any for sale at a reasonable price say under 350.00 bux?
Thanks Chris
Username: Freezeman_7
Lindsay, Oklahoma U.S.A
Post Number: 831
man i mono sub would be cheaper than a 1000x2 amp. get a mono amp. cheaper and better. jus my .02tho
Username: Nascarfan
Post Number: 44
Yea mono was what I was thinking as well, I would like to get at least 800rms to each sub at either 4ohm or 2ohm, or 1ohm.
Post Number: 833
no, if u get a 2000wrms mono amp. u will get 1000wrms to each sub. it will distribute the power evenly.
Username: Nascarfan
Post Number: 45
I thought about the Hifonics Brutus or maybe the CADENCE ZRS10, they have decent prices but are they reliable for every day usage.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=015&sspagename=STRK%3AMEWA%3AIT &viewitem=%26item%3D250098636133%26%26
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=015&sspagename=STRK%3AMEWA%3AIT &viewitem=%26item%3D250095266472%26%26
Username: 420alldaylong
Post Number: 1225
This amp will bang the s h i t out of those subs.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16368
Username: Josh1005
Norfolk, VA U.S.A
Post Number: 45
i have a JL 1000/1 and it powers my 3 12" JLs at 2ohms and it sounds real good. just a thought on the amp, i have no complaints it has alot of raw power
Username: Rovin
My 1 12 Atom...
Post Number: 11103
dude ignore max rating - look @ wrms so its 500wrms each x 2 though those subs can handle 600wrms cool
look for an amp that does 1200wrms @ 1ohm - go ebay ......
Username: Skies
Courtenay, British Colu... Canada
Post Number: 499
eD NINe.1.
$365 Shipped to your door.
http://www.edesignaudio.com/edv2/product_info.php?cPath=21&products_id=44
Username: Nascarfan
Post Number: 46
Thanks guys, looks like i need to do some searching
Username: Nascarfan
Post Number: 47
Hi what do you think about this amp here
AUDIOBAHN A1500HCT HIGH CURRENT MONO AMP 2000W?
Username: Nascarfan
Post Number: 48
Nevermind...I changed my mind on that amp
Username: Arande2
Extreme SQ FTW
Post Number: 2206
Just buy a Rockford Fosgate T15kw and be done with it.
Username: Nascarfan
Post Number: 49
lol.my credit line doesnt go that high :-)
Username: Bholt30
Union, Kentucky United States
Post Number: 16
try a sundown saz-1500D
