Ohms ?
Username: Mike_16
Burlington, Wisconsin Us
Post Number: 421
ok so if you have 2 dvc subs that are 2 ohms, an dhave a 1 ohm amp can you hook it up, i used ot know this but i just forgot bout it and how it worked , i think it has to be dual 4 ohm to hook up to 1 ohm right?
Username: Nyyfan13
Fi SSD USA
Post Number: 4520
2 dual 2 ohm subs cant be wired to 1 ohm...
2 dual 4 ohm subs can be wired to 1 ohm...
http://www.the12volt.com/caraudio/woofer_configurations.asp
Username: Mike_16
Post Number: 423
ok so would it be better to have 2 dual 4 ohm subs and a 1 ohm amp? or would it be better to have 2 dual 2ohm subs with a 4 ohm amp,
Username: Goodie_goop
Midland, Texas U.S.
Post Number: 472
two dvc 2 subs can wire to 2ohm
u need dvc 1 or dvc 4 to get two subs to a 1ohm load
Midland, Texas U.S.
Post Number: 473
get 2 dual 4 with a 1ohm stable amp
you cant run 2 dual 2ohm subs at 4ohms
Username: Nyyfan13
Fi SSD USA
Post Number: 4522
what subs and amp are yuo looking at?
2 dual 4 ohm subs wire to a 1 ohm or 4 ohm load
2 dual 2 ohm subs wire to a .5 ohm or 2 ohm load
2 dual 1 ohm subs wire to a 1 ohm load
Username: Imalik
SD2.5, New Jersey Ocean
Post Number: 201
Your amp is not 1 ohm...its 1 ohm stable...meaning you have a few more wiring options.1-2-4 ohms
Username: Mike_16
Post Number: 426
yanks fan i will prolly be runnin 2 12's alpine 4 ohms type r's and i was thinking 2006 hifonics, but unless i could maybe get a lil more money and what would you guys use for them to get the most power outs them? what amp around 300 bucks?
