HO alternator dealers?
Username: Jtown
Post Number: 12
Can anyone let me know where I can find a dealer either in Texas or Colorado, or just give me some contact info?
Also, how much do they usually run for?
Thanks
Username: Nd4spd18
Southeast PA
Post Number: 968
Most local electrical shops don't build HO alternators. And don't fall for their "we can rebuild your stock alt to do (insert really high amperage here) number of amps" crap. Most of those shops don't know WTF they're talking about.
If you need an HO alternator, Ohio Generator are among the best out there:
http://www.ohiogen.com/
Iraggi alts are also good:
http://stores.ebay.com/Iraggi-Alternator-and-Electronics
Also remember to look at the idle amperage rating when shopping for a HO alt, it is important. If a company won't tell you how many amps their alt does at idle, don't buy it.
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1571
http://www.motorcityreman.com/
Where I got mine. Have to admit it finally died after a couple years of use, but since it was built in a stock housing I just put the original back in. However, the prices here are very reasonable and when informed of the problem they offered to fix the thing np. I just never got around to sending it in as the stock alternator did just fine with the power I was utilizing.
-Fishy
Username: Jtown
Post Number: 14
What should the amperage be at idle?
Username: Nd4spd18
Southeast PA
Post Number: 1035
The more the better, same goes for the regular amperage. The alternator that I am looking at for my truck is 220 amps and 175 at idle.
Username: Jtown
Post Number: 21
How much is that costing you?
I'm going to need a large one for my next setup, I actually need one right now,but it's not too big of a deal yet.
Username: 420alldaylong
Post Number: 1198
http://www.highoutputalternator.com/
Post Number: 1199
This will help.
http://www.termpro.com/articles/electsys.html
Username: Oleg
Santa Monica, CA USA
Post Number: 673
We're not leaving out excessive amperage. Arguably, lowest priced HO alts. Lots of people seem to like great customer service and no BS - that's what you get there.
Username: Th3pwn3r
Post Number:...
Post Number: 1617
"We're not leaving out excessive amperage. Arguably, lowest priced HO alts. Lots of people seem to like great customer service and no BS - that's what you get there."
That wasn't very clear Oleg.I've heard just as many bad things about Excessive amperage as good things and in my eyes that isn't good enough.I've never heard of problems with Iraggi Alts and that's what I run and there's great customer service from Iraggi.Dominick's a cool guy too.
Username: Oleg
Post Number: 686
Recently there have been many complains about Dom not answering emails and taking 2 months to deliver and alternator. I don't think Iraggi is cheaper than EA, so pricewise they're at least the most competetive. I have not heard anyone say Nate didn't respond to emails though. But I am talking from my own experience - perhaps he gave me great CS and shytty to others.
Username: Bumpndatrunk
Milwaukee, WI USA
Post Number: 74
why is motorcityreman so much cheaper then others will it put out what it says
Username: Oleg
Post Number: 694
dunno...don't they only make alts for domestic vehicles? those are usually cheaper than imports.
