Looking for a nice 4 channel amp...
Username: Jaguar600
Post Number: 127
I am trying to find a relatively inexpensive 4 channel amplfier, but still something that will get the job done a little better than a headunit will. I found the Pioneer GM-4300F. Is this a decent amp?
Username: 420alldaylong
Post Number: 1235
Not sure on that amp but how much do you want to spend on a amp.
Username: Jaguar600
Post Number: 128
Well I found that amp for $100 shipped so somewhere around there would be great.
Post Number: 1240
Little more than the other but better.
http://www.sonicelectronix.com/item_3579_Kicker+KX200.4+.html
Username: Jaguar600
Post Number: 130
hmm I was looking at that kicker too.. Any other suggestions? I saw some power acoustics for good prices but I dont think they are very good... Also its going onto a factory radio if that helps
Post Number: 1242
Stay away from Power Acoustics VERY overated.
http://www.millionbuy.com/powasa4004.html
http://www.millionbuy.com/phgr504.html
http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=5673
There all good but the kicker is the best out of those I listed. I hope this helps you out,
Username: Oleg
Santa Monica, CA USA
Post Number: 706
How much power do you need per channel?
Username: Riskyb
Post Number: 536
Diamond Audio D3400.4 about 160$ on ebay. Good audiophile quality and nice looking aesthetics.
Username: Jaguar600
Post Number: 131
looking for only about 40+ watts rms per channel. Instead of putting a headunit in i am going to put in an amp.
Username: Jaguar600
Post Number: 132
Between these 2 what do ya think...
http://www.parkaveelectronics.com/product.asp?itemid=PIOGM4300F&l=Froogle
I never really heard about phoenix gold. Would it be a better amp than the pioneer? ALso it doesnt have speaker level inputs so where do I get the adaptor to convert to racas?
Username: Tibr6
My 2 cents would be to upgrade the factory radio to a better aftermarket radio before you do anything else. Thats the best upgrade you can do. For amps I would use an Orion HP-4600 or the Kicker.
Username: Jaguar600
Post Number: 133
But I can get more power out of an amp rather than a new headunit and I dont need a new headunit the factory one is fine. Also if I take out the factory one I need to put in a $150 mounting kit to not lose the information center and I spend less putting a new amp in rather than a headunit and the mounting kit.
Username: Oleg
Post Number: 711
I see what you're saying. You want something louder and cleaner and you don't want to spend a lot? I would take that diamond audio that Grant suggested. The kicker and orion are also nice. If those are too expensive, I'd take the PG over the pioneer. HU upgrade is something you'd want to do soon though.
Post Number: 1250
Out of those two get the PG.
Username: Jaguar600
Post Number: 137
Alright sounds good thanks alot
Username: Luvbass
To, Ca United states
kicker is way under rated, if it says 40 rms its more like 55 my zx750 is rated supposed to be 750 at 2 ohms, certified 932rms at 2 ohms, love kicker amps, some of the best on the market ive seen
