Help Please!!!!!!!!!!!!!!!!!!!!!!!!!!!
Username: Clark09_5hotmailcom
McCook, Nebraska
ok so i just hooked up my subs and amp and if i turn the bass up any louder than ten notches on my stock head unit it makes my subs cut out and about 5 seconds later they start bumpin again which if i turn the bass down than it wont do that. It should be hitting a lot harder than it is. any suggestions? also i have 4 guage wire
Username: Carguy
Post Number: 6033
You need to set the gain/level on the amp properly. If not, you'll the same problem repeating over and over till the amp dies.
McCook, Nebraska
Post Number: 8
I honestly dont know what that is
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4304
well, then read the manual and learn a lil bit
Username: Carguy
Post Number: 6035
Look at the amp. It should have some buttons and dials. One of them will say "gain" or "level". Adjust that according to your HU's preout voltage. If you're not sure, most HUs are around 4v, older ones were 2v, and newer ones are up to 8v.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11704
3 threads for the same damned problem you culd have fixed yourself by RTFM?
lovely.
Username: Djbeanpole
Naptown, Indiana USA
Post Number: 356
Is this the original post?
