What frequency test track did u guys set ur gains at?
Username: Oaktowncrazyd
East Oakland, CA
Post Number: 43
topic^^^^^
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11690
I use a full spectrum pink noise generator for that.
even power output @ 20-20KHz
That way I can see the curve on an RTA, too.
Username: Dj_007
Carlisle, KY US
Post Number: 66
for setting the gain just on subs i used a calculator i found on the internet.. i will get a link ... but anyways you put in the fuse rating on it and how much power it is supposed to put out and it will give you a certain voltage it should put out at 60hz to keep from clipping.. then you hook up a multi meter to the terminals play a 60hz tone and adjust the gain to the voltage output that is recomended
