Is this a good amp
Username: Xfacta82
Post Number: 19
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=446
or
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3807
or
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=253
Username: Nd4spd18
Southeast PA
Post Number: 1094
Yes, yes, and yes. PG, Eclipse, and JL are all good brands.
Username: Xfacta82
Post Number: 20
Which would you suggest for running CDT HD-62 in front and CDT CL-69x in back
Username: Matt12490
California USA
Post Number: 2039
None of those. The PG looks to put out the most power, but the Eclipse and JL are both underated. Anyways, you should go with two amps because the HD set can handle two times more than those coaxials. I would get two 2-channel amps, one that does 200x2@4ohms and one that does 100x2@4ohms. OR you can get a 4 channel amp that does 200x4@4ohm and turn down the gain on the on the two channels that the coaxials are on.
Just what I think would be best.
Username: The_image_dynamic
San Diego
Post Number: 748
^^^^ x2
