SSD came today, woohoo
Username: Volfenhagking1600
I WILL be 15 Wangin
Post Number: 426
can i join the 15" wangers club and possibly get a sticker?Upload
A pic is worth 1000 words
Post Number: 4931
Great feeling, isn't it?Upload
Los Angeles, CA USA
Post Number: 11440
very nice. welcome to the club.
Username: Nyyfan13
Fi SSD USA
Post Number: 4439
looks nice...give a review when installed
Username: The_image_dynamic
San Diego
Post Number: 684
Congrats man, you have come along way from the Volfenhag.
I WILL be 15 Wangin
Post Number: 429
thank you, one question. How do you wire the sub to 1 ohm for the kickerzx750.1?
I WILL be 15 Wangin
Post Number: 430
and how long should i break in the sub?
San Diego
Post Number: 686
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Los Angeles, CA USA
Post Number: 11441
that amp is 2ohm stable.
Username: Jblanford
Post Number: 625
whats the vc config on your sub ?
San Diego
Post Number: 687
dual 2 so he is in a quandary with that amp.
I WILL be 15 Wangin
Post Number: 431
no my sub is dual 1
San Diego
Post Number: 688
Well then you are all set, wire it the same as the diagram for dual 2's and it will be a 2 ohm final load.
I WILL be 15 Wangin
Post Number: 432
alright thanks
I WILL be 15 Wangin
Post Number: 433
wiring option #1 ???http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=1&woofer_imp=3
San Diego
Post Number: 690
No like this:
I WILL be 15 Wangin
Post Number: 434
for a dual 1 ohm sub? really? my amp is 2 ohms stable though. im not sure i get all this ohms material
San Diego
Post Number: 691
^^^^That is series -- meaning that if you wire your dual 1 ohm sub like that the final load to your amp will be 2 ohms.
Username: Nyyfan13
Fi SSD USA
Post Number: 4441
wire how brad has it...same principle for wiring a dual 2 ohm sub to a 4 ohm load...but your wiring a dual 1 ohm sub to a 2 ohm load
I WILL be 15 Wangin
Post Number: 436
alright thanks for clearin that up guys
I WILL be 15 Wangin
Post Number: 437
now...how should i have logan build my box. I have a 96 grand prix so its gunna be inna trunk?
Username: Nyyfan13
Fi SSD USA
Post Number: 4442
http://subwoofertools.com/forum/ported-box.asp?Ew=25&Eh=17&Dia=9&Xmax=16&Vd=.2&N umW=1&Vb=3&Fb=32&Qts=&Vas=&Fs=&CE=0
designed by mat dope for a friend of mine but if it fits in your trunk itd be nice...im sure logan will know what to do...he makes very nice boxes
