How do u hook up turn on wire
Username: Thump510
Oakland, Ca U.s
Post Number: 24
how do you hook up turn on wire to hu
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11753
use a wire to connect the turn-on lead from the amplifier to the "REM" trigger wire on the head unit.
if there isn't a REM(remote) wire on the harness, use the power antenna "PWR ANT" lead.
should be a blue or blue with white trace wire.
