DD 500 Series
Username: Splsq
Chesterland , Ohio USA
Post Number: 39
Im thinking about getting 2 12inch DD 500 subs. Are these pretty good subwoofers. Like are they loud and clean.
Username: Splsq
Post Number: 40
I plan i on putting them in a sealed box so they sound alot better and more crisp but im afraid they wont be to loud. I had 2 12inch Kicker CVRs in a sealed box and they pounded real nice.
Username: Jkidder
Spring hill, Florida Usa
Post Number: 371
might consider steping up to the 1500 series. wat amp do u have?
Username: Splsq
Post Number: 41
well im on a budget and im buying from Kevin Holden and for 325 im getting 2 12inch DD 500s and a Massive Audio amp and im on a 400 dollar budget.
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 4041
port them if you can. DDs sound best and loudest by far when ported.
Username: Splsq
Post Number: 43
Well i heard its better to keep subs sealed if u want nice crisp bass. alls i got to say is im lucky cause kevin is sellin his used he bought them to test them out.
Username: Adddisorder
West palm, Florida
Post Number: 3849
port them at 32hz and they be nice and loud and still sound good.
Username: Splsq
Post Number: 45
well im on a budget so i found a ported box on ebay that will do. but i will probaly order them tom so i cant wait
Username: Goodie_goop
Midland, Texas U.S.
Post Number: 435
dont order one off ebay cus it is not built to the specs of the sub and wont sound like it could if one is built for the subs...build your own box or have somone build it for you
West palm, Florida
Post Number: 3856
x2 build your own box or get logan to do it for you
