HELP WITH OVERRIDE CODE FOR JENSON VM9311
Username: Butafuco83
Post Number: 7
I TRIED THE CODE AND THE MOVIE WOULD POP UP FOR A SECOND AND THEN GO BACK TO THE BLUE SCREEN
Username: Choopz
Aruba
Post Number: 15
Hi,
I had the same problem you are having but I just kept on doing it step for step (you have to remember the code)and do it one by one. I know it is very stressful because of the blue screen poping back up but just do one step at a time until you set the override function and you're dun.
